Old 04-08-2010, 12:27 PM   #1
new 15 amp breaker sparking
i am trying to wire (6) 85 watt recessed lights...i have used 14 gauge wire...i dedicated a line to the breaker...did all the proper wiring...i.e. white/ground to the neutral bus bar...snapped in the new breaker to an available bus...turn it on...and a spark occurs where the wire meets the newly installed breaker...
any suggestions?
rgentil32 is offline   Reply With Quote
Old 04-08-2010, 12:38 PM   #2
Master Electrician
is it a subpanel....if so you can't have you neutral and ground on the same bar. Most likely it's a lose connection at the breaker. Or you've got a short somewhere on the line. Does the breaker trip?
andrew79 is offline   Reply With Quote
Old 04-08-2010, 01:13 PM   #3
it is a newly installed panel (3 years ago) attached to the existing 20 year old one...it appears as both white and bare (ground) are attaching to the bus...i just did the same w the new one...
Old 04-08-2010, 01:21 PM   #4
Master Electrician
Did you strip the insulation from the end of the conductor before connecting it to the breaker?
brric is offline   Reply With Quote
20 amp GFCI breaker pops when pool pump is turned on. jagrunner Electrical 11 03-19-2010 05:31 PM
small voltage on circuit with breaker off jasonmechler Electrical 3 08-24-2009 09:52 AM
Sq D Trillaint Breaker problem jmreynol Electrical 3 04-28-2009 08:06 PM
20 Amp Breaker tripping with GFCI panhandlion Electrical 7 12-12-2007 09:59 PM
Outdoor breaker panel questions lhoney2 Electrical 12 07-19-2007 06:44 PM
