Never Pulled Wires Before. - Electrical - DIY Chatroom Home Improvement Forum
Old 12-13-2009, 04:52 PM   #1
Never pulled wires before.
Got a sub panel installed upstairs this weekend. Running 1 inch PCV conduit down to the basement then outside to main breaker panel. I will be pulling three 8 guage THHN and one 10 guage for ground for a max of 40 amps. Total length is going to be around 60 feet and about 8 elbows. I will have at least 3 LB boxes in place of elbows (think that's what they're called.) Is it going to be difficult to pull all 4 wires at once or should I opt to pull them one at a time?
thanks
Mike in Arkansas is offline   Reply With Quote
Old 12-13-2009, 04:56 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,990
ALL at once! It's the ONLY way.
Old 12-13-2009, 04:58 PM   #3
Allrighty, thanks. I assume I pull them from LB box to LB box and not try it all at once?
Old 12-13-2009, 05:16 PM   #4
Exactly. You CANNOT pull through an LB, box or conduit body.
Old 12-13-2009, 05:30 PM   #5
thanks again sir.
Old 12-13-2009, 05:42 PM   #6
I don't even want to know how you managed to get 8 elbows in a mere 60 feet
Your conduit is plenty big but I am guessing it will be a challange for you to pull/push it.
220/221 is offline   Reply With Quote
Old 12-13-2009, 05:52 PM   #7
There is also wire lube that can be used to coat the wires
If you have short pulls between LB's you may not need it
But if you have 2 elbows in a row it helps
Old 12-13-2009, 06:44 PM   #8
Hum, lets see. 1. out the panel side up to attic. 2 across rafters. 3 change direction to opening to access hole to basement. 4. down the access hole. 5 and 6 in basement to exterior wall. 7 8 and (oops) 9 on exterior wall to main. Actually 3 or 4 of the elbows will be LB's. And I could have run more direct but opted to leave accessible space in the attic by keeping the conduit up out of the way against the rafters.
I'll look into the lube, at least if I can get it in small quantities.
Old 12-14-2009, 12:32 PM   #9
Tired & Dirty
Rewards Points: 83
you can get quart bottles of lube at Lowes or Menards, don't be stingy when applying it either. A little lube always helps when pushing & pulling.
evapman is offline   Reply With Quote
Old 12-14-2009, 01:10 PM   #10
Old 12-14-2009, 04:29 PM   #11
Remember, four 90's max between JB's/LB's......but try and use only 3.
Old 12-14-2009, 05:46 PM   #12
Rewards Points: 1,016
How much to apply is a question - I was taught to do a good squirt down the conduit hole every couple feet of wire as it goes in. Sound about right?
Old 12-14-2009, 10:21 PM   #13
Every two feet. Yep, sounds about right.
Old 12-15-2009, 06:46 PM   #14
Electrical Contractor
kbsparky's Avatar
Sheesh, with that many LB's and a total run of 60 feet, you probably won't need any lube. Especially if you get some Sim-pull wires!
-KB
Old 12-20-2009, 05:38 PM   #15
Never pulled wires before Redux
Can't say that anymore It sure would have gone quicker with 2 people. I had carefully measured my conduit run using a tape measure and measuring from elbow to elbow and came up with 63 feet. Just to be safe I cut my wires at 70 feet to give myself plenty of leeway. Turns out, if I had cut them 4 inches shorter they would have been too short Anyway, that's over now and I can start to run branch circuits to the upstairs baths and bedrooms. thanks to everyone for their advice on my project.
Switch Junction box has 3 sets of 3 wires. Can't get dimmer to work knockout Electrical 14 01-10-2015 09:08 AM
Confusing Chandelier Wires Burnsy Electrical 21 02-22-2009 03:29 PM
Unfused connectors MELTED House wires WHAT TO DO??? jamiedolan Electrical 63 02-12-2009 06:01 PM
Heil DC90 - AC Wires keithshank HVAC 1 07-31-2008 08:37 PM
Two black wires with one white! Please help! ibs325 Electrical 15 11-18-2007 09:38 PM
