Old 11-12-2009, 08:30 AM   #1
Neutrals and grounds in main panel
I've got a detached garage, with its own 100 amp main service feeding it, not a sub panel. My question is can I land the neutrals and grounds on the same busses or do I need to seperate them. The two bars are bonded together and bonded to the panel and I realize I can't put them both on the same terminal. But is it ok to put neutral, ground, neutral, ground, etc. on the same bus? Thanks in advance for your help.
steve37887 is offline   Reply With Quote
Old 11-12-2009, 08:48 AM   #2
Xtreme DIY'r
If it's a service feed then neutral & grounds are connected buss bonded to the case
Is this fed right from a meter & not from a disconnect of any kind ?
Old 11-12-2009, 09:01 AM   #3
Yes, that is correct, it is fed directly from the meter.
Old 11-12-2009, 09:06 AM   #4
It is good practice to keep the neutrals on the neutral bus and the grounds on the ground bus, even though they are bonded in the main panel.
Usually the bond is hidden under the cover for the main so someone besides yourself looking in there may not know they are bonded and therefore equivalent.
Is your cable too short, box too full or something? Why not just connect them correctly?
Salem747 is offline   Reply With Quote
Old 11-12-2009, 09:12 AM   #5
Xtreme DIY'r
In my Main panel I usually land them on whichever side of the panel box they come in from
If the wire enters on the left I land them on the left
I dislike having the wire cross behind the main hots to get to the other side
And going down around the bottom of the panel is a lot of extra wire
The only time I would seperate is if I planned on installing a new Main & knew the panel would become a sub-panel
Old 11-12-2009, 09:18 AM   #6
All 3 of my panels have both neutral and ground busses on either side of the panel. I wouldn't try to cross over, that just makes a mess, but if possible, using the correct busses just means that someone won't take off the cover and go "WTF was this dude thinkin! Grounds on the neutral bus? Neutrals on the ground bus? Was he colour blind or something?"
Old 11-12-2009, 09:20 AM   #7
That was my reason for wanting to land them on the same buss if I could Dave. To me it looks neater to bring the cable in on the side the breaker it feeds is on and then land the neutral and ground at the closest terminal rather than fishing wire all over the panel to seperate. I just wanted to make sure it was legal to do this, I didn't see why it wouldn't be since both are bonded together anyhow, before I did and made my wires too short to reach the other side.
gfci in main feeding sub panel problem scott2332 Electrical 12 02-26-2009 12:17 AM
Nuetral from feeder cable to main panel question? TW Lucas Electrical 14 05-08-2008 12:33 PM
breaker panel question chadvavra Electrical 11 08-10-2007 10:20 AM
Outdoor breaker panel questions lhoney2 Electrical 12 07-19-2007 06:44 PM
Splice in Neutral to Panel - OK or Not? allpraisebob Electrical 4 08-12-2006 06:54 AM
