Neutrals - Electrical - DIY Chatroom Home Improvement Forum
Old 01-26-2009, 02:24 PM   #1
Neutrals
I want to add a 15A circuit and I have an unused 15A breaker which was added by en electrician about 12 years ago. The breaker was added when another 15A circuit was added. They were both extened to a 4 inch box in my crawl space. The unused circuit ends there.
I noticed that the two 15A circuits are on the same side of the panel and the electrician only extended one neutral. Should I added another neutral run from the panel before I use the unused circuit. I would assume it is desirable to keep the neutrals paired with the hot and not mix and match (although I understand that is often done).
I would appreciate any advice.
measure thrice is offline   Reply With Quote
Old 01-26-2009, 02:33 PM   #2
Are these runs both in the same conduit?
Or is it a single cable?
Old 01-26-2009, 02:34 PM   #3
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
Are they on the same side and next to each other? For example, circuits 4 and 6. If so, you would just need to tie the handles together or get a double pole 15 or pull another neutral.
wirenut1110 is offline   Reply With Quote
Old 01-26-2009, 03:06 PM   #4
circuit numbers
I'm not near the box right now, but it is the upper left breaker and the ajacent breaker below it. They are the wider breakers as some of my circuits have a pair of separate breakers occupying the same real estate.
Yes, they do go through the same conduit.
Maybe I should just pull another neutral because it is a 3/4 inch conduit with only 4 wires in it. There is ample space and the run is less than 6 feet to the 4 inch box where the runs will split.
Old 01-26-2009, 03:07 PM   #5
Rewards Points: 510
That would be the best thing to do.
Old 01-26-2009, 04:56 PM   #6
Electrician
SD515's Avatar
Rewards Points: 504
I agree with wirenut. Pair them up at both ends with tape or preferably a tie strap, so you know (at both ends) which neutral goes with which hot.
Kyle
Old 01-26-2009, 04:57 PM   #7
That's easy, yeah I'd just pull another neutral
Old 01-28-2009, 11:38 PM   #8
Thank you all
Thanks for the advice
Old 01-28-2009, 11:47 PM   #9
DIY'er
jamiedolan's Avatar
Rewards Points: 1,024
Smile
Make sure to use Thhn. Jamie
Jamie Dolan - Neenah, WI
Jamie Dolan Paw Dogs
Need Help Uploading Photos? Click here.
jamiedolan is offline   Reply With Quote
Old 01-29-2009, 12:40 AM   #10
I would say use it as a MWBC and replace the two single pole breakers with a double (required as of recently), but because the run is so short, and the conduit is so wide, adding a neutral sounds like a winner.
thegonagle is offline   Reply With Quote
Old 01-29-2009, 12:56 AM   #11
Licensed Electrician
Magnettica's Avatar
Rewards Points: 150
Send a message via Yahoo to Magnettica
For the homeowner, adding a separate neutral here is the wise thing to do.
Magnettica is offline   Reply With Quote
Tags
neutral
Wiring Neutrals together. Randell Tarin Electrical 37 05-30-2008 11:19 AM
Hall light worked before installing a new light fixture in bathroom jcfan7 Electrical 40 02-23-2008 10:46 AM
breaker panel question chadvavra Electrical 11 08-10-2007 10:20 AM
connecting multiple neutrals toghether best way? J187 Electrical 4 08-17-2006 10:35 AM
Lack of neutrals in new building userabuser Electrical 2 10-21-2005 06:53 PM
