Neutral Wires - Electrical - DIY Chatroom Home Improvement Forum
Old 12-18-2010, 01:05 PM   #1
Neutral wires
I have a switch box with two switches and one neural wire. Can I splice both withches into a single neutral wire?
Dryfly is offline   Reply With Quote
Old 12-18-2010, 01:07 PM   #2
DIYer
That really depends on how its wired. In a switch box the white wire might not even be neutral at all. Can you give more details?
Gigs is offline   Reply With Quote
Old 12-18-2010, 01:16 PM   #3
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
and you do not switch the neutral either, which, without more explanation, appears to be your intent.
Hot white wire joined to neutral wires! dogdutyascetic Electrical 22 10-04-2012 09:22 AM
Connecting ground to neutral in old 120v 2-prong outlet flow Electrical 15 11-08-2010 12:15 PM
3 Wire Set Up . . . Neutral Wire Tied to Ground Wires irishMonster Electrical 14 10-21-2010 08:20 AM
240 volt load/appliance and ground vs neutral kgize Electrical 7 04-22-2010 11:40 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
