Neutral Wires - Electrical - DIY Chatroom Home Improvement Forum
Old 03-22-2007, 08:06 AM   #1
neutral wires
can neutral wires from different circuits be tied together, so that only one wire is added to the nuetral bar?
Talman48 is offline   Reply With Quote
Old 03-22-2007, 10:13 AM   #2
Licensed Pro
As a general rule, no.
But in older panels with limited space on the neutral bars, it is a much preferred method to placing two neutrals under one screw (a NEC violation). Make sure the two circuits are on different hot legs so the total load on the neutral pigtail is the difference between the circuit loads and not the sum.
Old 03-22-2007, 05:25 PM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,864
How about absolutely NOT. Even if you are using two separate circuits on different legs of the service.
Old 03-22-2007, 05:27 PM   #4
jproffer's Avatar
Rewards Points: 706
It's an even more preferred method to either quit adding circuits that your panel can't hold...or change the panel to one with more capacity.
jproffer is offline   Reply With Quote
12v diff between ground and neutral at panel am9518 Electrical 7 02-25-2008 07:28 PM
Subpanel feeder questions Silhanek Electrical 4 03-22-2007 07:30 PM
Old house, new light fixture, too many wires Persephonee Electrical 3 01-15-2007 09:58 AM
Suspected open/loose service neutral mrtomwj Electrical 5 09-28-2006 09:46 AM
Splice in Neutral to Panel - OK or Not? allpraisebob Electrical 4 08-12-2006 06:54 AM
