Neutral Wire To Switch? - Electrical - DIY Chatroom Home Improvement Forum
Old 09-26-2011, 06:00 PM   #1
Rewards Points: 358
neutral wire to switch?
I just purchases some new switches for my bathroom fans, I currently have the wind up timers on them, these new ones are fancy push button times. the problem is they require a neutral wire. How so I go about getting a neutral wire down into the switch box if all that's in there is the hot wire?
Do I need to pull out the electrical box that's in the wall and run a totally new wire? I just dont see an easy way of getting a wire from the attic into an existing switch box halfway down the wall.
Also can I tap into any neutral wire or does it have to be the same neutral that the switch curcuit is on?
cbzdel is offline   Reply With Quote
Old 09-26-2011, 06:15 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,252
Has to be the same neutral as the power feed to the fan. Pull out the existing 2 wire cable and replace with a 3 wire cable. Sometimes it is easier to knock out the old box, fish in the new cable and replace the box.
Coastal South Carolina
The Following User Says Thank You to rjniles For This Useful Post:
Code05 (09-27-2011)
Old 09-27-2011, 04:34 AM   #3
Code05's Avatar
Rewards Points: 1,104
Yep. 300.3(B)
Conductors of the Same Circuit. All conductors of
the same circuit and, where used, the grounded conductor
and all equipment grounding conductors and bonding conductors
shall be contained within the same raceway, auxiliary
gutter, cable tray, cablebus assembly, trench, cable, or
cord, unless otherwise permitted in accordance with
300.3(B)(1) through (B)(4).
Code05 is offline   Reply With Quote
Old 09-27-2011, 09:47 AM   #4
Rewards Points: 358
Thanks guys!
fan/light switch buzzing mjlocat Electrical 4 05-23-2010 02:44 PM
Red Wire Travler and Switch Operation ferrerij Electrical 3 03-14-2010 10:48 PM
4 way switch confusion Richo Electrical 10 04-09-2009 07:11 AM
Neutral Wire? 4x15mph Electrical 8 11-24-2008 01:00 PM
can't get new light fixture to work carolcwilson Electrical 24 08-12-2008 12:52 PM
