Neutral Wire Splice In Breaker Panel - Electrical - DIY Chatroom Home Improvement Forum
Old 02-22-2012, 12:09 PM   #1
Rewards Points: 51
neutral wire splice in breaker panel
Is it ok to have the main neutral wire spliced from the meter to the buss bar.
I bought a house that the panel has been replaced everything else looks fine but the neutral wire must of been a little short
joelowrider is offline   Reply With Quote
Old 02-22-2012, 12:41 PM   #2
Licensed electrician
Rewards Points: 996
It is possible to splice, but I would just replace the conductor.
How is the panel operating now?
Old 02-22-2012, 12:50 PM   #3
Rewards Points: 51
panel is fine no issues just worried about the wire. So there is not going to be an issue if I ever sell this house or should I have the wire replaced
Old 02-22-2012, 01:39 PM   #4
Rewards Points: 996
Can you post a pic?
Old 02-22-2012, 06:53 PM   #5
did you just buy this house? was it inspected?
Hardway is offline   Reply With Quote
Old 02-22-2012, 07:28 PM   #6
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
I would replace it. How many amp service?
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 02-23-2012, 07:48 AM   #7
Rewards Points: 51
yes and yes but the inspector said nothing about it
Old 02-23-2012, 08:15 AM   #8
rrolleston's Avatar
The home inspector should have noticed it if he was expected to check out the electrical systems.
Old 02-23-2012, 08:27 AM   #9
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,032
I have never seen a home inspector remove a panel cover. They might look for breaker sizes and uncovered openings in the panel but not the guts of the panel. You would need to hire an electrician for that.
Coastal South Carolina
Old 02-23-2012, 08:48 AM   #10
"I have never seen a home inspector remove a panel cover."
Permit and Inspection, just another form of taxation. Oh when they are collecting the fees they are through. You have to pull the permit and have inspections but donít think you are any safer.
Old 02-23-2012, 09:19 AM   #11
rrolleston's Avatar
It seems to me they should at least take the cover off to note the obviouse issues. The 500 or more for a full home inspection for insurance and mortgage purpose just to do a quick walkthrough it seems like a lot.
Old 02-23-2012, 09:25 AM   #12
Licensed Pro
Done all the time here. My biggest gripe about it is all the stuff they miss. Might as well not even bother to look.
Old 02-23-2012, 09:30 AM   #13
I thought he would at least pull a cover or fixture and look. Or even test a GFCI, I asked if he wanted me to do the same He said no. Ten minutes and poof like Keyser Soze, he disappeared.
Old 02-23-2012, 09:46 AM   #14
Rewards Points: 712
If it's a little short, how did they connect it? A picture would be worth a lot here.
Mark
busman is offline   Reply With Quote
Old 02-23-2012, 10:05 AM   #15
Rewards Points: 51
<a href="http://s144.photobucket.com/albums/r...rrent=mail.jpg" target="_blank"><img src="http://i144.photobucket.com/albums/r...rider/mail.jpg" border="0" alt="Photobucket"></a>
breakers with multi wire branch circuit (shared neutral) corman Electrical 0 09-11-2011 12:52 AM
Tripping breakers,neutrals,120 volts and 240 volts OH My!!! Stubbie Electrical 17 06-11-2011 07:09 AM
200A upgrade and move, backfeeding permitted? WillK Electrical 3 05-30-2011 09:00 PM
Grounding a mess! CapnSteubing Electrical 13 08-31-2009 11:07 AM
Nuetral from feeder cable to main panel question? TW Lucas Electrical 14 05-08-2008 12:33 PM
