Neutral Wire But Fell Off In Inaccessible Place - Electrical - DIY Chatroom Home Improvement Forum
Old 05-28-2012, 09:48 PM   #1
Unhappy
Neutral wire but fell off in inaccessible place
A wire but fell on my head when installing a light fixture and I can see it is from two wire wires but I can't access it without opening the ceiling.
How bad is it to leave it as is?
Thanks!
Waterfroggy is offline   Reply With Quote
Old 05-28-2012, 09:54 PM   #2
Licensed electrician
Rewards Points: 1,024
I am guessing you mean wire nut? If so the splice should already be in an accessible junction box. There should be not need to open the ceiling. If the splice is not in a box this needs to be fixed.
Do not leave the splice open.
2 wire outlets: connect neutral to ground? border collie Electrical 19 04-12-2013 01:29 PM
Need to know if my grounds and neutrals are connected right dorlow Electrical 185 01-15-2012 03:54 PM
ceiling fan wicked97 Electrical 4 08-21-2011 09:12 AM
Neutral wire and Ground wire hooked together PIGEONS Electrical 4 11-16-2010 06:22 PM
Is using a ground wire as neutral wire safe? Head Fred Electrical 9 12-18-2008 03:37 PM
