Neutral Terminals For A New Circuit In An Existing Panel? - Electrical - DIY Chatroom Home Improvement Forum
Old 10-22-2008, 05:38 PM   #1
Unhappy
Neutral terminals for a new circuit in an existing panel?
I installed a new spot light on a building. Ran all the wires to the panel which has about 5 available 20 amp circuits. However looking at the neutral terminals they are all full. I am wondering if or how to terminate another neutral in this panel. Thanks.
superick is offline   Reply With Quote
Old 10-22-2008, 06:16 PM   #2
joed's Avatar
Rewards Points: 12,422
Add another neutral bar. You can't double up neutrals under one screw.
Old 10-22-2008, 06:16 PM   #3
If it's the main panel, double up two of the same size grounds in one hole. Sub panel, add another nuetral bar.
jerryh3 is offline   Reply With Quote
Old 10-23-2008, 11:51 AM   #4
Rewards Points: 126
Your not supposed to double up on grounds either. Stupid rule, but a rule none the less. However, some panel manufacturers do have UL listing for more than one wire under a screw or lug. I think Square D Homeline is one of them. I think.
Best to just install another neutral terminal.
Old 10-23-2008, 12:06 PM   #5
Who's rule is that?
Old 10-23-2008, 12:26 PM   #6
Registered User
Termite's Avatar
Originally Posted by jerryh3 View Post
Who's rule is that?
I have yet to (knowingly) come across a residential panel that wasn't listed to have more than one grounding conductor of the same size under the same lug. That's a new one on me.
As for neutrals...Can't ever double them.
Old 10-23-2008, 12:55 PM   #7
Are you aware of any local codes anywhere that prohibit it?
Old 10-23-2008, 02:17 PM   #8
Registered User
Termite's Avatar
Not around here, but there's a lot of municipalities around the country!
Old 10-23-2008, 02:25 PM   #9
I'm sure there's at least one out there.
Ground rod or not? brotherman Electrical 30 07-15-2008 04:58 PM
12v diff between ground and neutral at panel am9518 Electrical 7 02-25-2008 06:28 PM
breaker panel question chadvavra Electrical 11 08-10-2007 09:20 AM
Splice in Neutral to Panel - OK or Not? allpraisebob Electrical 4 08-12-2006 05:54 AM
Adding new circuit breakers to 100 amp sub panel DrP Electrical 8 05-25-2006 10:05 PM
