Neutral Size Question - Electrical - DIY Chatroom Home Improvement Forum
Old 01-13-2009, 07:59 AM   #1
neutral size question
I'm replacing my oven, which had 30 amp service, with a slightly larger one that requires 40 amp service (all 240 vac).
My original service was 240 vac single phase, using 2 10 awg stranded with a 12 awg neutral, in 1/2 inch emt conduit.
According to a NEC table I looked at, I can pull up to 3 8 awg thhn wires in 1/2, which looks like a full plate to me. Can I use the same rule of thumb as the original installer, and use two 8 awg conducters with a 10 awg neutral, as I already have an all metal conduit ground path?
tommy potatoes is offline   Reply With Quote
Old 01-13-2009, 09:00 AM   #2
Rewards Points: 2,350
If its 240, why do you need a neutral?
Old 01-13-2009, 09:51 AM   #3
Rewards Points: 1,452
A 240 volt only branch circuit does not need a neutral. If 120 volt usage is also intended then you need a neutral; the ground does not suffice. A 240 volt (stove) receptacle that has a neutral contact must be fed with a 120/240 volt circuit (with neutral). Most electric stoves also require 120 volts including for clocks, timers, etc.
Old 01-13-2009, 10:15 AM   #4
I think he knows that. He's asking the OP why he needs a neutral if he states the oven is 240V load.
jerryh3 is offline   Reply With Quote
Old 01-13-2009, 10:25 AM   #5
My old oven had the neutral hooked up, and the installation instructions for the new one call for it, too.. And yes, everything with electronic displays most likely utilizes the neutral to provide 120vac service to the LVPS.. I understand that much.. So, since the neutral is not called in to play for more than 120V mains for a LVPS, I guess 10 awg is plenty, eh?
Electrical connections TazinCR Electrical 11 01-07-2009 08:10 PM
Will reverse polarity trip breaker?? Duane 70 Electrical 60 12-05-2008 11:18 PM
Which neutral is which? Jeremy Hillary Boob, PhD Electrical 5 11-28-2008 12:11 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
Ground rod or not? brotherman Electrical 30 07-15-2008 05:58 PM
