Neutral Return Problem - Electrical - DIY Chatroom Home Improvement Forum
Old 05-19-2009, 06:58 AM   #1
Neutral return problem
I was installing a new outlet in my bathroom and the power was turned off at the breaker so I thought I was safe. Much to my surprise when I touched the neutral wire I received quite a shock. Any ideas as to what the problem is? There are other lines being fed from this outlet.
Barry2080 is offline   Reply With Quote
Old 05-19-2009, 08:03 AM   #2
Rewards Points: 508
Send a message via AIM to theatretch85
Always treat a circuit as if it was live! Sounds like you didn't turn the power off to the correct circuit, or you have a multi-wire branch circuit where the neutral feeds 2 circuits. Check to see if there is a red and a black wire that supplies power into the box or leaving the main panel.
I believe this is part of the reason the 2 pole breakers are required for MWBC in the new code cycle.
theatretch85 is offline   Reply With Quote
Old 05-19-2009, 08:05 AM   #3
Licensed Pro
That neutral is being shared with another circuit, either as part of a multiwire circuit, or improperly tapped to provide a return path for a random circuit.
Detached Garage Sub Panel Grounding Q integlikewhoa Electrical 15 03-12-2015 07:02 PM
Neutral problem, not sure what to do now BataviaJim Electrical 37 01-03-2009 11:00 AM
receptacle circuit problem jsherrill77 Electrical 22 12-25-2008 09:16 AM
Electrical "arcing" problem? morden5b Electrical 17 12-17-2008 06:10 PM
Will reverse polarity trip breaker?? Duane 70 Electrical 60 12-05-2008 10:18 PM
