Neutral Question - Electrical - DIY Chatroom Home Improvement Forum
Old 12-14-2012, 03:22 PM   #1
Rewards Points: 77
Neutral question
Hey everyone,
If I have 2 feeds (14/2) going to a 3 gang box to feed:
1st feed for plugs, wall sconces
2nd feed for all potlights
Do the neutrals need to be separated or can they be all joined together.
Does it matter?
mlijoi is offline   Reply With Quote
Old 12-14-2012, 03:26 PM   #2
Licensed electrician
Rewards Points: 1,486
Unless the CEC is different than the NEC the neutrals need to be kept separate. The grounds should be connected together.
Old 12-14-2012, 03:28 PM   #3
Rewards Points: 77
Thanks,
I had a feeling!
Old 12-14-2012, 03:45 PM   #4
Rewards Points: 1,494
When two feeds enter a junction box, the neutrals are not combined. The neutral for each downstream load is connected only to the neutral accompanying the hot line that supplies that load.
Old 12-14-2012, 03:48 PM   #5
Rewards Points: 77
Gotcha! Thanks!
2P 240v GFI Breaker neutral question Skelleyman Electrical 4 08-15-2012 06:43 AM
electric grounding bar in main panel steve gregory Electrical 13 01-22-2012 02:20 AM
Unused ground lead as neutral? ramatsu Electrical 13 01-10-2012 07:44 PM
Knob and tube neutral question gbwillner Electrical 2 11-07-2009 09:34 AM
Main disconnect neutral wiring Daniel Holzman Electrical 5 10-04-2009 01:36 PM
