Neutral Question - Electrical - DIY Chatroom Home Improvement Forum
Old 05-09-2012, 02:51 PM   #1
Neutral Question
I am having a rough in inspection for detached garage sub-panel tomorrow and I'm wondering whether or not I should have the feeder neutrals and/or grounds connected at the main and/or sub panel?
MisterSteve is offline   Reply With Quote
Old 05-09-2012, 03:25 PM   #2
Well, of course. It's one of the main things that will be inspected, making sure it's installed and hooked up properly
hawkeye11 is offline   Reply With Quote
Old 05-09-2012, 03:30 PM   #3
It's my understanding that no "hot" wires should be connected at the panels until the very end. I guess my confusion is whether or not the neutral is ever considered hot as a feeder or otherwise.
Old 05-09-2012, 03:42 PM   #4
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Is there a reason why you can't connect it?
What is a rough inspection for a sub panel? Are you talking an open trench inspection?
Old 05-09-2012, 03:59 PM   #5
For the main feeder to the sub-panel, it needs to be 'service ready' for the rough-in inspection. Meaning it needs to be able to be energized at the time of the inspection.
For the individual feeders in the garage, yes just hook up the neutrals and the grounds in the sub-panel.
Old 05-09-2012, 05:03 PM   #6
Old 05-09-2012, 05:04 PM   #7
k_buz's Avatar
finish up the wiring and leave it turned off. You will not fail inspection for terminating the wires.
Generator & Interlock Kit Float the Neutral? Arnold Ziffel Electrical 12 01-13-2013 05:28 PM
electric grounding bar in main panel steve gregory Electrical 13 01-22-2012 02:20 AM
Unused ground lead as neutral? ramatsu Electrical 13 01-10-2012 07:44 PM
Knob and tube neutral question gbwillner Electrical 2 11-07-2009 09:34 AM
Help if it's not too late!! Cyndi Electrical 255 10-10-2008 09:18 PM
