Neutral In Light Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 12-05-2012, 10:40 AM   #1
Rewards Points: 202
Neutral in light switch
Hypothetical Question regarding new requirement of neutral wire at switch.
If power is run to the light and then 3 conductors to the switch (2 for the switch leg and 1 for the neutral), what happens to the neutral at the switch? Is it just capped off in case it is needed and then connected to the neutral at the light?
Thanks.
Also, wouldn't this open the possibility of someone using the neutral as a hot to expand from the switch--something you wouldn't be able to do on a two conductor switch leg.
benleef is offline   Reply With Quote
Old 12-05-2012, 11:18 AM   #2
Licensed electrician
Rewards Points: 1,474
If the neutral is not needed by the switch it would just be capped off.
This would also allow the circuit to be extended from the switch at a later date.
Old 12-05-2012, 12:16 PM   #3
TTW
TTW's Avatar
Also, if you ever install one of those motion sensing switches or lighted switch, you need the neutral to be there. I believe it is now code to run neutral to all switch boxes in new installations.
TTW is offline   Reply With Quote
Light fan burn out, wall switch backwards later LOYD DUNCAN Electrical 1 09-18-2012 06:49 AM
Ceiling fan - Light on dimmer switch, Fan on normal switch renderflux Electrical 3 09-10-2012 01:36 PM
Light in one lighted three-way switch not working dalepres Electrical 2 06-26-2012 06:27 AM
1 source 3 separate switches elchildress Electrical 3 12-31-2011 09:51 AM
Switch neutral wiring Terabitdan Electrical 4 12-29-2011 06:03 PM
