Neutral And Grounding Buses - Electrical - DIY Chatroom Home Improvement Forum
Old 06-30-2008, 12:03 PM   #1
Rewards Points: 1,062
Question
neutral and grounding buses
i just noticed that the neutral and grounding buses had been used interchangeably by the previous owner of the house and i kind of cleaned it up: concentrated neutral on the one where neutral was the majority and vice versa.
Q1: but, since it did work OK before, i was wondering if they can be used interchangeably ? my neutral bus is also running out of slots and i need to add a few more circuits so was wondering if i can use the grounding bus, which has more vacancy as it is, for some reason, bigger.
Q2: if the cannot be used interchangeably and the previous owner was sloppy, is there any way to find out which one is really which (since the majority principle i described above is not necessarily to be trusted - as is usually the case with all things in life).
thanks,
- a -
Old 06-30-2008, 12:11 PM   #2
Licensed Pro
If this is the main service disconnect panel, then they can be used interchangeably. If this is a subpanel, then they must be kept separate.
Old 06-30-2008, 12:14 PM   #3
Question
thanks. why is it different, if you don't mind me asking ?
Old 06-30-2008, 12:54 PM   #4
Power Gen/RS Engineer
Rewards Points: 566
In the main service panel, ground and neutral busses are bonded together. In a sub, they are intentionally isolated from one another for safety reasons. In the latter case, if they were bonded and the feeder neutral became broken or disconnected, the ground would be carrying the neutral current back to the service and possibly bring exposed parts to some potential higher than ground.
Well, now, there's what's right and what's right and never the twain shall meet.
BigJimmy is offline   Reply With Quote
Max amps allowed - electrician advice needed Des Electrical 27 06-05-2008 10:31 PM
Range Outlet Receptical Wiring - PICS nave Electrical 45 05-29-2008 06:37 PM
Nuetral from feeder cable to main panel question? TW Lucas Electrical 14 05-08-2008 11:33 AM
advice on installing equipment grounding bar in main panel pacifier1er Electrical 5 05-29-2007 05:55 PM
Suspected open/loose service neutral mrtomwj Electrical 5 09-28-2006 08:46 AM
