Neutral And Ground Wire Connections - Electrical - DIY Chatroom Home Improvement Forum
Old 12-17-2011, 09:50 AM   #1
Neutral and ground wire connections
As I look at my load center, I noticed that the neutral wires and ground wires both go to the same bar. I would have thought these would be separate. Is this normal?
wavewuver is offline   Reply With Quote
Old 12-17-2011, 09:55 AM   #2
Licensed electrician
Rewards Points: 996
In service equipment this is perfectly normal and code compliant. In any panel after the first means of disconnect it is not proper.
Old 12-17-2011, 10:06 AM   #3
Thanks for the quick reply.
3 Wire Set Up . . . Neutral Wire Tied to Ground Wires irishMonster Electrical 14 10-21-2010 09:20 AM
Sharing Neutrals on the same phase electro Electrical 30 08-12-2010 03:10 PM
240 volt load/appliance and ground vs neutral kgize Electrical 7 04-23-2010 12:40 AM
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 08:40 PM
Ground rod or not? brotherman Electrical 30 07-15-2008 05:58 PM
