Old 06-06-2012, 09:45 PM   #1
Neutral bus corrosion
I have a 30 year old 100 amp Murray service panel. The screws in the neutral bus bar (aluminum) are corroded, not horribly, but obviously. What should I do at this point?
TIA
JeffT is offline   Reply With Quote
Old 06-06-2012, 09:47 PM   #2
What is the location of the panel?
IntexInspector is offline   Reply With Quote
Old 06-06-2012, 09:48 PM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Nothing until it fails.
If there is obvious water infiltration then you should find the source and fix it.
The Following User Says Thank You to Speedy Petey For This Useful Post:
electures (06-06-2012)
Old 06-06-2012, 10:38 PM   #4
Electrical Contractor
rrolleston's Avatar
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
I would turn the main breaker off clean up the connections and add some ox guard to the connections. Bad neutrals can cause all sorts of undesireable effects.
Please ask me about my special discount for people that shut up and stay out of my way! With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 06-07-2012, 01:28 PM   #5
It's in a very dry basement. Really, there are such things in New England. They're just RARE . . .
Old 06-07-2012, 02:51 PM   #6
What type of basement,concrete block,poured concrete,stone? Is there laundry in the basement?
Old 06-07-2012, 04:26 PM   #7
Fieldstone. 100 years old. I just added laundry, vented to the outside . . .
Old 06-07-2012, 05:45 PM   #8
E2 Electrician
stickboy1375's Avatar
Im sure the humidity is a lot higher than you think, run a dehumidifier... most stone foundations i've worked in all have panel issues with corrosion...
stickboy1375 is online now   Reply With Quote
Old 06-07-2012, 08:01 PM   #9
Loosen and then retighten each screw and set screw that holds wires in place in the panel. This cleans and therefore improves the connection.
Do not use tremendous force.
Should something break in the process then it was too far gone, corrosion wise.
Each neutral (white) wire must have its own hole and screw in the neutral bus bar. Two ground wires (green or bare) of the same size can share a hole.
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
Old 06-07-2012, 08:19 PM   #10
E2 Electrician
You might want to suggest they turn off the breakers before loosening any neutral connections...
Induction Cooktop, no neutral (?!) andersol Electrical 7 09-28-2010 04:47 PM
Sharing Neutrals on the same phase electro Electrical 30 08-12-2010 03:10 PM
question on the "stubbie" bonding links n175h Electrical 12 10-13-2009 05:09 PM
Main disconnect neutral wiring Daniel Holzman Electrical 5 10-04-2009 02:36 PM
Ground rod or not? brotherman Electrical 30 07-15-2008 05:58 PM
