Neutral Bar Blues - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-19-2008, 10:17 AM   #16
Originally Posted by InPhase277 View Post
You could pigtail the neutrals, as Jerry said. But, LISTEN CAREFULLY! You cannot just grab any ol' neutral and pigtail it to any ol' neutral. You can take two neutrals from circuits fed from opposite phases and pigtail them together and then to the neutral bar.
Or, you could tie any two neutrals together and use a #10 pigtail for 15 A circuits, and #8 for 20 A circuits. For the love of God, if you do go this route, heed the warnings above!
Forgot to post that part. Thanks. This makes it a mini-MWBC(sort of). HouseHelper's advice is better(Just make sure the tie bar/strap is reinstalled).
jerryh3 is offline   Reply With Quote
Old 12-20-2008, 11:41 AM   #17
Pictures
Here are a few pictures of the panel box to help clear things up.
Avramel is offline   Reply With Quote
Ground rod or not? brotherman Electrical 30 07-15-2008 04:58 PM
12v diff between ground and neutral at panel am9518 Electrical 7 02-25-2008 06:28 PM
Sub panel grounding sluggermike Electrical 27 11-11-2007 01:23 AM
Suspected open/loose service neutral mrtomwj Electrical 5 09-28-2006 08:46 AM
Splice in Neutral to Panel - OK or Not? allpraisebob Electrical 4 08-12-2006 05:54 AM
