Net Metering - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-16-2008, 11:52 AM   #16
Check with your local utility about net metering. This is also a state law thing, but this would have to do with the utility.
Basically you install solar electric panels, then use a "grid tie" inverter which synchronizes your electricity to the utility power and sends this power out on your line if you are generating more power than using.
Your utility may provide a meter which runs backwards or a meter which shows both directions.
Here is one manufacturer of grid tie inverters...
http://www.xantrex.com/web/id/172/p/1/pt/25/product.asp
Billy_Bob is offline   Reply With Quote
Old 10-17-2008, 08:10 PM   #17
Hello,
The way that I would like to run the generate is off of veg oil. I have someone that an help me with that process.
waitegarry is offline   Reply With Quote
Old 10-17-2008, 08:24 PM   #18
DIY
Rewards Points: 150
Expect to pay a lot more for your electricity than you are paying for it from the grid...
gp_wa is offline   Reply With Quote
Old 10-18-2008, 12:09 PM   #19
Originally Posted by waitegarry View Post
Hello,
Keep in mind that the fuel you use to go and get the veg oil will offset any savings you experience with this set up.
It's called money transfer. You transfer the money from your heating costs to your transportation costs.
Unless you are getting a 1000 gallons at a time it is not worth the trip.
My idea of a perfect day: No where to go and all day to get there.
Marvin Gardens is offline   Reply With Quote
