NEMA 6-50 And 14-50 On Same Line - Electrical - DIY Chatroom Home Improvement Forum
Old 08-20-2014, 01:28 PM   #1
Rewards Points: 332
NEMA 6-50 and 14-50 on same line
I am planning on installing a receptacle for a welder and was wondering if I could run 6-3 cable and have this line shared between the 6-50 receptacle and a 14-50.
Obviously, both receptacles couldn't be utilized for a full load at the same time.
sgip2000 is offline   Reply With Quote
Old 08-20-2014, 01:59 PM   #2
Rewards Points: 1,010
Should be fine
Anti-wingnut is offline   Reply With Quote
The Following User Says Thank You to Anti-wingnut For This Useful Post:
sgip2000 (08-20-2014)
Old 08-20-2014, 03:32 PM   #3
Rewards Points: 3,396
Originally Posted by Anti-wingnut View Post
Should be fine
Giving permission?
http://www.grainger.com/product/1MN3...140820203532:s
ritelec is offline   Reply With Quote
The Following User Says Thank You to ritelec For This Useful Post:
Old 08-20-2014, 03:42 PM   #4
Rewards Points: 332
Originally Posted by ritelec View Post
When would a "safety switch" be necessary?
Old 08-20-2014, 03:43 PM   #5
Rewards Points: 332
I meant to ask if anyone sees any problems with this configuration.
Old 08-20-2014, 03:52 PM   #6
What's your point?
Speedy Petey (08-20-2014)
Old 08-20-2014, 04:09 PM   #7
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
WHY in the world would that be necessary???
The Following User Says Thank You to Speedy Petey For This Useful Post:
Stubbie (08-20-2014)
Old 08-20-2014, 04:14 PM   #8
It's just like putting two 15A outlets on a single circuit.
Main Line Clog Master Brian Plumbing 46 09-06-2012 08:38 PM
Adding a second line to existing septic line Eddietan Plumbing 3 05-10-2012 09:27 AM
Old water supply line a_lost_shadow Plumbing 7 04-19-2012 11:12 PM
Condensate Drain Line Mystery (pan full but no primary clog?) CarrieLP HVAC 21 04-04-2012 11:07 PM
Capacity loss with line size Einride HVAC 1 06-29-2009 03:10 PM
