NEMA 14 Generator To NEMA 6 Pump Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 04-10-2012, 09:22 PM   #1
Question
NEMA 14 Generator to NEMA 6 pump wiring
Hi guys,
I've got a generator I'd like to hook up to a sump pump. The sump pump is 240V and comes with a NEMA 6-15 plug. The generator provides 240/120V (30A) output via a NEMA 14 Plug and 4 wire cable.
I've purchased 12-4 cable and the appropriate connectors to build a patch cord. I just wanted to confirm the wiring. I'm assuming
1. Connect ground to ground
2. Connect the hots (red to red and black to black)
3. Cap off the neutral (don't use it)
Is this correct? I've read some posts about binding the ground and neutral, why would you do that?
Thanks,
Chris
chatko is offline   Reply With Quote
Old 04-10-2012, 10:30 PM   #2
Electrical Contractor
kbsparky's Avatar
There is no neutral conductor connection in the NEMA 6-15 configuration.
-KB
Old 04-10-2012, 10:46 PM   #3
Rewards Points: 506
Hence the 240v designation?
jlmran is offline   Reply With Quote
Old 04-11-2012, 05:33 AM   #4
Rewards Points: 1,512
Yes.
You could use 12-2 cable with ground for the patch cord. Leave the neutral unconnected.
Tags
nema 14 nema 6 240v
Well Pump wiring question gfreely232 Electrical 24 04-16-2012 03:13 PM
question about septic pump & alarm wiring. ACR_SCOUT Plumbing 8 02-04-2012 04:19 PM
Swimming Pool Pump & Salt Water Ctlr Wiring brianr Electrical 1 06-27-2011 06:02 AM
Wiring 240v pump to generator - URGENT Benchr Electrical 4 12-19-2006 05:50 PM
Trane Heat Pump tstat replacement with Honeywell prog - wiring question sep23 HVAC 2 10-20-2006 09:10 PM
