Nema 10-30 To 14-30 - Electrical - DIY Chatroom Home Improvement Forum
Old 06-22-2013, 02:30 PM   #1
nema 10-30 to 14-30
I was moving an old nema 10-30 outlet and noticed it had a 4 wire cable with the bare ground cut off. The cable is 6/3 with ground. I measured less than 1 ohm between White and bare ground wires. The circuit is on 2 30-amp breakers in the panel.Can I just wire up a new 14-30 outlet using all wires?
unclemoose is offline   Reply With Quote
Old 06-23-2013, 01:46 AM   #2
Rewards Points: 512
Yes, BUT, #6 is a 75 amp gauge, and is overkill for a 30 amp circuit (should have been 10AWG), SO, what is this receptacle going to serve? This is important.
Installation is the Reverse of Removal.
Old 06-23-2013, 10:49 AM   #3
I was thinking I could run some light duty woodworking equipment - scroll saw, band saw, etc. My house was built in 1986 and the kitchen, dining room, basement, and part of the living room are all on one breaker. As I've acquired higher wattage kitchen appliances it's become apparent that some kind of electrical upgrade is in my future. So when I spotted this 220v outlet in the basement it seemed like a way to move away from using hand tools in the garage.
Old 06-23-2013, 11:06 AM   #4
Licensed electrician
Rewards Points: 1,296
Does your area have any codes adopted? The way your house was wired did not meet the codes of that timeframe.
Has work been done in the panel? The circuits may have be improperly doubled up.
Old 06-23-2013, 11:45 AM   #5
There is evidence that the bonehead I bought the house from, and original owner, did some, if not all of the electrical work. And carpentry, and concrete. I've come to realize just how incompetent he was in a number of areas.
Custom PA system - Help needed with wiring adequate power, supplied by a generator psygnome Electrical 0 08-05-2012 07:36 PM
Nema 10-30 Trying to better understand poles Sesom Electrical 11 07-25-2012 12:14 PM
Changing a nema 5-15r into a nema 6-20r Sesom Electrical 12 07-22-2012 06:23 PM
NEMA 14 Generator to NEMA 6 pump wiring chatko Electrical 3 04-11-2012 06:33 AM
Need help wiring for Nema 10-30 LHD Electrical 8 12-03-2009 11:28 AM
