Neighbor's AC Dims My Lights! - Electrical - DIY Chatroom Home Improvement Forum
Old 05-23-2009, 12:37 PM   #1
Neighbor's AC dims my lights!
My lights dim slightly when my neighbor's rather large AC unit comes on. Should I be concerned about this?
knharper is offline   Reply With Quote
Old 05-23-2009, 01:23 PM   #2
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
I would complain to your local Power Company, that is to whoever bills you for Power. It is in your interest to keep the incoming line voltage as high as possible, that is ideally when there is a minimal voltage drop between the pole Transformer and your meter.
When there is a notable dip in your line voltage when the neighbor,s AC comes on then you may also have a not noticeable lower line voltage due to the neighbor's non-cyclical loads.
Disclaimer
& Stay Safe
.....Bob Lavery
Old 05-23-2009, 02:27 PM   #3
Rewards Points: 502
Yes, call your utility provider.
I'd also recommend you get a plug in volt meter and see what your current voltage is and what it is when his A/C unit cycles.
-Andrew
DIY hobbiest
AndrewF is offline   Reply With Quote
Old 05-23-2009, 04:17 PM   #4
If your neighbor pulls 20A or 200A you should see a drop on your 240v between 300 or 3000 mVac and 20 or 200 mVac, more likely the lower values.
Finding underground electric wire for driveway lights. mitch21131 Electrical 25 09-24-2012 09:52 AM
Changing switch for lights in basement, confused on current wiring. RyanD Electrical 2 05-14-2009 09:37 PM
New lights in basement CooperChloe Electrical 11 01-11-2009 12:22 PM
Sump pump dims lights Richo Electrical 7 12-20-2008 04:00 PM
Adding can lights to an existing circuit TexasEd Electrical 1 06-17-2008 08:23 PM
