Neew Light Switch... On Is Ok(ish), Off Flips Breaker - Electrical - DIY Chatroom Home Improvement Forum
Old 05-04-2007, 03:23 PM   #1
neew light switch... on is ok(ish), off flips breaker
I put in a new light and switch, (i'm not a pro but done it loads of times before), and now none of the lights on that breaker work.
Turn breaker on just turns itself off now.
Have put the original lighting setup back in, and still nothing.
Does this mean I have a short?
Please be gentle with me.
Nat0570 is offline   Reply With Quote
Old 05-04-2007, 03:33 PM   #2
Can you tell us a little more about the situation?...Is it a 3 way set-up. Did you accidently attach the white wire to the switch....(do they have white wires in England?...lol). Did you mistakenly buy a 3 way switch?
send_it_all is offline   Reply With Quote
Old 05-04-2007, 03:43 PM   #3
errr... about the white wires...no.
red/brown is live.
green/yellow is earth and blue is the other one.
the switch was a dimmer switch, i think it did have L1 and L2
would that make a difference?
Old 05-04-2007, 03:53 PM   #4
With blue being the "other one" I'm guessing that means neutral. That should not be connected to a light switch. Only the "live" or "hot, and then the same color running to the fixture...
Another question....
When you take the switch out of the box completely....how many wires (romex cables) are entering the box from the back?..
If it is just one bundle or one romex with 2 conductors + a ground, then my advice regarding the white wires is not valid...if there are 2 or more, then only the "live" colored wires should be connected to the switch. I'm not an electrician so my lingo may not be right, but if I saw a pic, I could tell you which wires go where...lol
Old 05-04-2007, 04:08 PM   #5
So Cal Electrician
Send a message via Yahoo to hbsparky
ummmmm england is 50hz and I think most of their stuff is 220/240
Well....Butter my butt and call me a biscuit!
hbsparky is offline   Reply With Quote
Old 05-04-2007, 04:14 PM   #6
yes to 240v
loads of cables out the back
scared now
Old 05-04-2007, 04:17 PM   #7
me too... Ignore my posts above...a qualified guy is now on the scene.
Old 05-04-2007, 04:21 PM   #8
So Cal Electrician
sounds like it's a 2 pole switch. you need to find the two hots that are coming in and make sure you have them on the right screws. Sounds like you have a loop going. power into power, not power into switch leg...understand what I am saying?
Old 05-04-2007, 04:36 PM   #9
thanks, i'm going for a cry now
Old 05-04-2007, 04:36 PM   #10
So Cal Electrician
so it's working?
Old 05-05-2007, 06:02 AM   #11
am going to try it now(ish) thanks for all your help and hope i can do the same one day
Breaker for Spot light and outlet receptical hgiljr Electrical 4 08-16-2007 02:10 PM
Light Switch Keeps Tripping Breaker jackiesmom Electrical 23 05-24-2007 03:27 PM
add a second light to an existing 3 way switch circuit djohns10 Electrical 6 03-02-2007 08:16 PM
Light switch not working! jtbel Electrical 4 12-09-2006 07:34 PM
Wiring a light with switch....please help!! lindo1951 Electrical 19 10-16-2006 03:32 PM
