-   -   neew light switch... on is ok(ish), off flips breaker (http://www.diychatroom.com/f18/neew-light-switch-ok-ish-off-flips-breaker-8232/)
Nat0570 05-04-2007 02:23 PM
I put in a new light and switch, (i'm not a pro but done it loads of times before), and now none of the lights on that breaker work.
Turn breaker on just turns itself off now.
Have put the original lighting setup back in, and still nothing.
Does this mean I have a short?
Please be gentle with me.
send_it_all 05-04-2007 02:33 PM
Can you tell us a little more about the situation?...Is it a 3 way set-up. Did you accidently attach the white wire to the switch....(do they have white wires in England?...lol). Did you mistakenly buy a 3 way switch?
Nat0570 05-04-2007 02:43 PM
errr... about the white wires...no.
red/brown is live.
green/yellow is earth and blue is the other one.
the switch was a dimmer switch, i think it did have L1 and L2
would that make a difference?
send_it_all 05-04-2007 02:53 PM
With blue being the "other one" I'm guessing that means neutral. That should not be connected to a light switch. Only the "live" or "hot, and then the same color running to the fixture...
Another question....
When you take the switch out of the box completely....how many wires (romex cables) are entering the box from the back?..
If it is just one bundle or one romex with 2 conductors + a ground, then my advice regarding the white wires is not valid...if there are 2 or more, then only the "live" colored wires should be connected to the switch. I'm not an electrician so my lingo may not be right, but if I saw a pic, I could tell you which wires go where...lol
hbsparky 05-04-2007 03:08 PM
ummmmm england is 50hz and I think most of their stuff is 220/240
Nat0570 05-04-2007 03:14 PM
yes to 240v
loads of cables out the back
scared now
send_it_all 05-04-2007 03:17 PM
me too... Ignore my posts above...a qualified guy is now on the scene.
hbsparky 05-04-2007 03:21 PM
sounds like it's a 2 pole switch. you need to find the two hots that are coming in and make sure you have them on the right screws. Sounds like you have a loop going. power into power, not power into switch leg...understand what I am saying?
Nat0570 05-04-2007 03:36 PM
:thumbsup: thanks, i'm going for a cry now:cry:
hbsparky 05-04-2007 03:36 PM
so it's working?
Nat0570 05-05-2007 05:02 AM
am going to try it now(ish) thanks for all your help and hope i can do the same one day
