NEEDED: Unusual Switch Activating Device - Electrical - DIY Chatroom Home Improvement Forum
Old 06-28-2011, 01:55 AM   #1
Question
NEEDED: unusual switch activating device
Can anyone help? I need a battery powered IR or radio controled remote activated device which, when mounted next to a standard wall mounted light switch, will mechanically operate the manual on/off switch. This is not your usual A/C powered remote controled switch which replaces the mechanical light switch inside the switch box, but rather an independent device which attaches to or pushes against the manual light switch toggle, moving it up/down mechanically. This is a serious question, not some "class project" or idle experiment. If anyone knows of a company or website selling such a device, please let me know. Many thanks.
arbee is offline   Reply With Quote
Old 06-28-2011, 06:28 AM   #2
Rewards Points: 320
What's the purpose for the device? I dont know of a company that makes one, but it wouldn't be too hard to do. Just need a U that would fit around the switch with a servo motor attached to it. Why do you need it battery powered though if it is already next to a light switch which will have power run to it. Would save you from having to replace the battery.
I'm not sure if you're application is making it possible for someone who can't get to the light switch turn on the light, you could buy something like this for a lamp in the room...
http://www.thinkgeek.com/homeoffice/lights/bb52/
Or go back to the clapper.
autx790 is offline   Reply With Quote
Old 06-28-2011, 12:23 PM   #3
Needed: unusual device
Thanks AUTX790. Not able to construct electronics due to physical disabilities. Need to purchase ready made machine. If device can be plugged into 110v outlet, will be OK. Due to room lighting arrangements, need to control ceiling light by remote, but difficult to do wiring/installation modifications. Much easier to screw add-on toggle switch manipulator onto wooden wall. Addition of new floor lamp might be possible alternative, but room small & already full of necessary equipment around bed, making additional equipment/power cords logistically difficult. Does anyone else know where I can buy such a device? Thanks.
Old 06-28-2011, 02:05 PM   #4
Rewards Points: 6,652
Yes, they are called x10 & z-wave device. Check out smarthome.com
Old 06-28-2011, 03:17 PM   #5
Electrical Contractor
This may help.
http://www.chickenswitch.com/
hpp58 is offline   Reply With Quote
Old 07-07-2011, 02:01 PM   #6
reply to suggestions on switch device
Thanks gregzoll & hpp58. I will check out your info. Your kind assistance is much appreciated. R.B.
Illuminated switch ??? dave95sps Electrical 5 05-29-2011 06:11 PM
Float switch install instructions needed noone HVAC 16 05-15-2011 11:02 AM
Help needed to finish of a 3-way light switch mfmchen Electrical 9 05-12-2011 09:47 AM
Well Pump pressure switch help needed. slabm7 Electrical 20 11-03-2010 06:56 PM
Wiring 2 light fixtures to same switch and add outlet RyanS2000 Electrical 13 10-10-2010 03:17 AM
