Needed Decora Rocker Switch CFL Rated? - Electrical - DIY Chatroom Home Improvement Forum
Old 08-02-2012, 04:46 AM   #1
Needed Decora rocker switch CFL rated?
I'm looking for a Illuminated Decora rocker switch 2 wire that is CFL rated. Is there any available? At the present CFL's will lightly flicker with the switch off (67 volt) .
rodm1 is offline   Reply With Quote
Old 08-02-2012, 05:12 AM   #2
dmxtothemax's Avatar
Rewards Points: 5,104
If the rocker switch is iluminated when in the off position.
That would explain why the cfl's flicker.
Cause they arn't really off!
The neon lamps are wired across the switch.
So in the off position, a small current flows thru the neon,
Usually with a incandesant lamp, it is not enough to light it up,
But with cfl's it will cause flickering.
dmxtothemax is online now   Reply With Quote
Old 08-02-2012, 05:42 AM   #3
Thanks, What are my options to fix this?
Old 08-02-2012, 06:57 AM   #4
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Agreed with Post #2. Here is a schematic of an illuminated switch. The Neon
has a fairly high impedance so when a incandescent bulb (lower impedance)
is connected then most of the voltage is across the Neon.
However a much higher impedance CFL will have have a correspondingly lower voltage causing flicker if it comes on at all.
The negative side of using illuminated switches with CFL's is that the trickle current when the switch is off may lead to shorter bulb life.
Their is no easy solution as Pilot switches are I think ugly and they require a
neutral which probably has to be added.
Disclaimer
& Stay Safe
.....Bob Lavery
Old 08-02-2012, 10:20 AM   #5
JOATMON
ddawg16's Avatar
Rewards Points: 1,132
The guys above covered all the points.....
What is the application? Bathroom? If so, is there a fan in there on a different ckt?
Otherwise, you will have to pretty much plan on having to install a neut in the box....
Old 08-02-2012, 04:51 PM   #6
Its a Kitchen light with a receptacle in the same box. Could I use the receptacle's neutral? What switch would I need a pilot switch?
I might just go back to the incandescent light bulb or remove the lighted switch.
Old 08-02-2012, 06:56 PM   #7
If you can find a DPDT illuminated rocker switch that is mains rated,
you can wire one side to the internal lamp,
But you would need a neutral.
Not easy, but possible.
Old 08-03-2012, 11:55 AM   #8
Tool Geek
PaliBob's Avatar
Edit
was looking for style but I got it now as Decora in Post #1
But what about Color?
Disclaimer
& Stay Safe
.....Bob Lavery
Old 08-03-2012, 01:11 PM   #9
Licensed electrician
Rewards Points: 1,266
You cannot use the neutral from the receptacle. All the conductors of the circuit need to be in the same raceway or sheath. Ligthing also cannot be on the small appliance branch circuits.
Old 08-04-2012, 02:28 AM   #10
Tool Geek
PaliBob's Avatar
Originally Posted by rodm1 View Post
I'm looking for a Illuminated Decora rocker switch 2 wire that is CFL rated.......
An Illuminated switch has to dump the Illumination current (typically just a single neon) either through the load or directly to the neutral buss. If the load is Fluorescent then the neon is starved for voltage and either flickers or won't come on at all.
Without getting into your circuit configuration here is an illuminated switch circuit using a Decora Pilot Switch wired up so that it mimics a regular Illuminated switch except the neon current is dumped directly to neutral.
When the fluorescent lights are on the pilot Switch Neon is Off. It uses 3 Way switch as a single pole switch to the load while the other half turns off the neon indicator.
Disclaimer
& Stay Safe
.....Bob Lavery
Old 08-25-2012, 06:29 AM   #11
Thanks for the diagram. I whose using a 15w CFL and thought about trying a 23w CFL (start-up current higher) and over night it seems to have worked. If this dosn't work out long term I will try the 3 way switch as suggested.
Thanks everyone,
Wiring in a 4-way Switch RickSene Electrical 5 04-09-2013 08:25 PM
NEEDED: unusual switch activating device arbee Electrical 5 07-07-2011 02:01 PM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 02:24 AM
Connecting Decora Switch cprao Electrical 9 03-30-2010 12:59 PM
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 04:06 PM
