Need Wiring Help With A Bathroom Exhaust Fan - Electrical - DIY Chatroom Home Improvement Forum
Old 04-11-2010, 07:56 PM   #1
Question
Need wiring help with a bathroom exhaust fan
I'm trying to replace our exhaust fan with a NuTone 769RFT. The instructions assume you're wiring it with Romax 12-2 (hot, neutral and ground) which is pretty straight forward. The problem for me is the lead is 14-3 (black, red, white and ground). The fan needs to be wired so both the light (white plug) and the fan (black plug) come on together. The switch is single-pole.
So I just need to know which wires to pair up together. Below is a picture of the wiring harness.
The black plug is for the fan and has black, green and white wires.
The white plug for the light as blue and white.
Brieninsac is offline   Reply With Quote
Old 04-11-2010, 08:06 PM   #2
joed's Avatar
Rewards Points: 12,028
Sounds like it was cabled to allow for separate switching of fan and light.
Connect the whites to the white.
Connect the green to the bare.
Connect the black and blue to the black.
If the fan/light don't work then connect the black and blue to the red wire.
The Following User Says Thank You to joed For This Useful Post:
Brieninsac (04-16-2010)
Old 04-16-2010, 12:55 PM   #3
Thanks Joe, that worked.
Old 04-16-2010, 01:06 PM   #4
Electrician
Rewards Points: 780
Like Joe said you could put a double switch where your single pole switch is and then you would be able to leave your fan on while the light is off.
darren is offline   Reply With Quote
Bathroom light/exhaust fan/heater wiring Redlos Electrical 39 10-31-2009 05:21 PM
Bathroom exhaust... the ongoing saga... landev HVAC 9 01-05-2009 08:49 PM
Help with bathroom wiring - URGENTLY NEEDED cfonseca Electrical 4 02-16-2007 02:42 AM
Wiring electric heater in bathroom PatSea Electrical 5 01-06-2007 10:40 PM
bathroom exhaust fan wiring ventureman Electrical 1 11-29-2006 06:52 PM
