Need URGENT Help With Question Regarding Fixing Electrical Panel In Home - Electrical - Page 5 - DIY Chatroom Home Improvement Forum
Old 10-06-2012, 12:43 PM   #61
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Half hour of time and a couple wirenuts...$100
The Following User Says Thank You to k_buz For This Useful Post:
asledge (10-06-2012)
Old 10-06-2012, 01:07 PM   #62
Rewards Points: 2,516
Originally Posted by Rochsolid View Post
you war an upgrade?
What?
Buy the house as get the upgrade
What?
hammerlane is offline   Reply With Quote
Old 10-06-2012, 06:37 PM   #63
Rochsolid's Avatar
Originally Posted by hammerlane
What?
What?
You want the upgrade, but the house as is and get the upgrade. My apologies for my quick typing
Rochsolid is offline   Reply With Quote
Old 10-06-2012, 06:49 PM   #64
Rewards Points: 258
simmular issue here i have an Fedral Pacific panel
http://www.inspectapedia.com/fpe/fpepanel.htm
I didn't know about the issue with this panel just got a bad vibe when i looked at it. but in the offer before we had and inspector look at the house we asked for an upgrade to 200amp service and a new load center. the electricen gave us a price over the phone of 3000, the electricen the owener called in looked at the stituation and said 950 for the new load center, i thought this was okay till i found out about the current load center, now i know it will cost more. jsut waiting for the office home inspection report and to talk to the realistate agaent again.... the orignal plan was to turn the curent panel in to a subpanel till later then move every thing out to the new panel (load center)
redman88 is offline   Reply With Quote
Old 02-22-2013, 03:40 PM   #65
Building tradesman
better late than ------
Plan on completeing the upgrade yourself but I hope you insisted all the issues concerning anything at all that would flicker be rectified. Flickering is not a normal electrical condition under any circumstances. Period and should be investigated and corrected.
I personally would insist. Can o worms might just actually be rusty too.
For what it is worth the last 2 zinsco services installed on houses I did work on had welded or rusted mains that would not open electrically. Condensation from the riser and no deflection had rendered them useless.
Zinsco went out of business for a reason.
dudleydoright is offline   Reply With Quote
Old 02-22-2013, 04:11 PM   #66
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
Originally Posted by dudleydoright View Post
For what it is worth the last 2 zinsco services installed on houses I did work on had welded or rusted mains that would not open electrically. Condensation from the riser and no deflection had rendered them useless. Zinsco went out of business for a reason.
Have had the same happen with many other brands too. Moisture will do that to any panel. Have a murray panel change coming up that breakers are suck on the the bus and the main won't open. Have also see it happen to square d panels.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 02-22-2013, 04:49 PM   #67
Blank
This thread is ridiculous. Had it occurred to you, the OP, that the seller does not have to do anything. Perhaps there is a situation where it is not an option for her to get beat down 4000 in her asking price. You are buying the house and although you can ask for some concessions I don't find her position unreasonable. And at the point you have pushed to get these changes made I would have told you there was no way, on principle alone, I would sell you the house.
Secondly, coming on here and asking for estimates is ridiculous. Although the electricians on here can give you rough ideas without seeing things in person there is no way they can be overly accurate.
Buying an old house means you get old house issues that you are responsible for. I promise that even though you may get this solved, as soon as you get confident and comfortable things are going to to break and fall apart. It is the nature of the beast.
I would say I wish you the best of luck but sadly, I don't. I feel you are asking for a lot after the seller has told you their position. You obviously have little respect for her.
Baxter01 is offline   Reply With Quote
Tags
amp , electric , home , panel , power
Roof leak to electrical panel via flashing? daluu Building & Construction 10 06-29-2012 07:19 PM
Section 310.15(B)(6) vs. 210.4. Don't assume, call your friendly AHJs! Daneel Electrical 3 04-11-2012 07:24 AM
Question about sub panel ground Richo Electrical 17 04-25-2011 09:18 AM
Outdoor PVC to panel question Jonathan- Electrical 12 09-18-2010 04:56 PM
mobile home service to bond or not to bond rikmac Electrical 35 03-17-2010 03:47 PM
