Need Tutorial On Wiring New Switch To Light. - Electrical - DIY Chatroom Home Improvement Forum
Old 01-06-2015, 04:35 PM   #1
Rewards Points: 274
Need tutorial on wiring new switch to light.
I want to put a new light at the bottom of my stairs.
I have a junction box in the basement with a wire in it that powers outlets on the first floor. I'd like to run a new wire from this junction box to the pole switch to the light.
Does anyone have a tutorial on how to do this starting from the junction box?
Mikeron is offline   Reply With Quote
Old 01-06-2015, 05:41 PM   #2
Rewards Points: 2,516
Here is power into the switch location then onto the light.
NOTE: ground wires not show for ease of drawing
Need tutorial on wiring new switch to light.-incom-out-sw-1-2-out-hot-2-2.jpg
hammerlane is offline   Reply With Quote
The Following User Says Thank You to hammerlane For This Useful Post:
Chris130 (01-06-2015)
Old 01-06-2015, 05:43 PM   #3
Here is how you would grab power from the location of a receptacle.
Old 01-06-2015, 05:45 PM   #4
FIDO...
Rewards Points: 241
Your diagrams always rock, hammerlane - nice!
Chris130 is online now   Reply With Quote
Old 01-06-2015, 06:02 PM   #5
Rewards Points: 274
Excellent thank-you and how will they look in the junction box, at the moment there is one wire into it and a wire going out?
Old 01-06-2015, 06:09 PM   #6
The connections in the J-Box Will look like the diagram in post 3 with the receptacle removed. In the existing j-box you say there are two cables. Are the blacks of the cable connected together. And the whites?
Old 01-06-2015, 06:12 PM   #7
I hope you actually mean cable when you say wire
Old 01-06-2015, 07:04 PM   #8
Rewards Points: 274
Yes the blacks and whites are together. So I take the nut off the two blacks and add the third light switch black and put the nut back on the 3 blacks and do the same with the 2 whites making 3 whites?
Old 01-06-2015, 07:04 PM   #9
Rewards Points: 274
Yes sorry, cable.
Old 01-07-2015, 09:36 AM   #10
Rewards Points: 1,568
*I recently posted some photos on my web site depicting the installation of a dimmer switch and a new ceiling light fixture. It is probably not exactly what you are dealing with, but you might get some useful tips.
http://www.mrelectrician.tv/question...itchLight.html
You may find that an old work fan brace and box will fit into the ceiling space between two joists nicely.
John Grabowski
MrElectricianTV is offline   Reply With Quote
The Following User Says Thank You to MrElectricianTV For This Useful Post:
samjg1 (01-11-2015)
3-way switch wiring (for kitchen light) mikevoth Electrical 22 04-12-2013 11:37 PM
Wiring instructions for a motion sensing light switch kfwhitfo Electrical 1 03-02-2013 02:15 PM
Light in one lighted three-way switch not working dalepres Electrical 2 06-26-2012 06:27 AM
Changing A Double Switch to a single pole switch and a dimmer switch loydbrahn Electrical 0 11-08-2011 11:00 PM
Hunter Fan Dual Switch Wiring Configuration Help schierle Electrical 2 03-29-2009 08:00 PM
