Need To Split Swith Controlled Outlet - Electrical - DIY Chatroom Home Improvement Forum
Old 03-29-2009, 01:09 PM   #1
need to split swith controlled outlet
I have an outlet that both receptacles are controlled by the same switch. I need to change it so that one is switch controlled and the other is always hot.
Thanks!
Nancy
summertimefa is offline   Reply With Quote
Old 03-29-2009, 01:20 PM   #2
It's probably not going to happen.
You need to take off the cover plate and unscrew the recep to see how many and what kind (colors) of wiring is in the box.
Turn off the power first
220/221 is offline   Reply With Quote
Old 03-29-2009, 01:32 PM   #3
dSilanskas's Avatar
Thanks!
Nancy
Open up the outlet and let us know what you have for wires
dSilanskas is offline   Reply With Quote
Old 03-29-2009, 01:49 PM   #4
The outlet has one white wire (left) and one black wire (right) going into the center of the back of the outlet. (and one copper ground wire going into the bottom of the back of the outlet).
Old 03-29-2009, 02:08 PM   #5
To make this recep 1/2 switched, you would need to run a new cable from somewhere like the switch or a close by recep.
Look on the other side of the wall and see if there is a recep close.
Old 03-29-2009, 02:09 PM   #6
Electrical Contractor
jbfan's Avatar
Rewards Points: 536
You can not split this receptacle with the wires you have now.
You would need an extra wire.
Old 03-29-2009, 02:17 PM   #7
The switch (and a second outlet) are about 4' away, above and to the left.
Old 03-29-2009, 02:26 PM   #8
How are you drywall patching skills?
You need to get a cable, sized the same as the existing, from the other recep to the one you want 1/2 switched.
You will need to cross at least two vertical studs to get there, or go up and over, thru the attic.
This is an easy DIY project ONLY if the walls were open.
Old 03-29-2009, 02:51 PM   #9
My drywall skills are fine..... bigger headache is an ornate tile back splash on the switch side (and a window between the attic and the target outlet). I really don't want to tear into the tile. Would have been way too simple for this to be just a move a wire motion, but I do have another outlet that can be used. Thank you so much for the simple answer I was looking for!
Old 03-29-2009, 07:14 PM   #10
jbfan's Avatar
Rewards Points: 536
You can do the same thing by going into the basement or crawl space.
help with wiring ceiling fan from a switch controlled outlet teamster807 Electrical 39 10-27-2011 04:09 PM
Electrical outlet controlled by a wall switch? rinlo Electrical 14 12-28-2008 10:30 PM
Help with outlet controlled by switch craigpall Electrical 2 05-18-2008 08:08 AM
Define Split Outlet And Why Needed In Kitchen bobo Electrical 6 10-18-2005 10:35 AM
Outlet controlled by switch Shardi Electrical 4 10-09-2005 06:24 PM
