Need Some Help Wiring A Combination & 3-way Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 01-04-2014, 10:57 AM   #1
Rewards Points: 150
Need some help wiring a Combination & 3-way switch
Hi all, need some assistance.
I have an existing 3-way switch that controls a ceiling light in the entry area from the garage. I recently just build a mudlocker that I am wanting to put a switched light in.
My goal is to tie into the existing 3-way switch and add a combination single pole/3-way switch to control the ceiling light and mudlocker light.
Does anyone have a diagram or willing to walk me through the correct wiring sequence?
The 3-way switch I am looking to tie into has (2) black wires, a red, and a ground.
Thanks!
stradt03 is offline   Reply With Quote
Old 01-04-2014, 11:12 AM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,034
Not enough info to really answer but if the switch box does not have a white wire, no neutral is available and you cannot feed another switch/light. What is the wiriing method (cable or conduit) ?
What is a mud locker?
Coastal South Carolina
rjniles is offline   Reply With Quote
Old 01-04-2014, 11:20 AM   #3
Rewards Points: 150
Originally Posted by rjniles View Post
Not enough info to really answer but if the switch box does not have a white wire, no neutral is available and you cannot feed another switch/light. What is the wiring method (cable or conduit) ?
actually I did some digging and there is a bundle of white wires tied together. I'll get a picture up here in second.
Mudlocker = bench with cubbies by garage door.
Old 01-04-2014, 11:22 AM   #4
Rewards Points: 150
Originally Posted by stradt03
actually i did some digging and there is a bundle of white wires tied together. I'll get a picture up here in second. Mudlocker = bench with cubbies by garage door.
Old 01-04-2014, 12:19 PM   #5
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Trying to understand what your doing. It looks from the picture that you have a cable coming into the box at the upper left and this I am assuming is the cable to the new mud locker light. Then it appears you have removed a 3 way switch and are going to install the combination switch in its place .. is that correct ?
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 01-04-2014, 12:24 PM   #6
Rewards Points: 150
That is correct. The cable coming into the box is the new cable to the mud locker light. The 3-way switch has already been removed and the new combination switch is attached. The combination switch has one 3-way switch (to replace the removed 3-way) and a single-pole switch (to control the mud locker light).
Old 01-04-2014, 12:35 PM   #7
UAW SKILLED TRADES
Stubbie's Avatar
One of those two blacks needs to be power or constant hot. If the 3 way is on the switch leg of the circuit, in other words one of the blacks is a traveler from the companion three way switch elsewhere and the other black goes to the ceiling light you won't be able to switch your mudlocker light independently. so in a nutshell you need constant power present in that box to do what you want.
Stubbie
Old 01-04-2014, 12:42 PM   #8
Rewards Points: 150
Top black wire stays hot regardless of the position of the other switch.
Old 01-04-2014, 01:05 PM   #9
UAW SKILLED TRADES
Stubbie's Avatar
Yes find which of the two blacks is paired with the red wire in the same cable. Test the other black wire it will either be hot or no power. The fact that no whites are connected to the old 3 way tells me that one black will either be hot constant or black to the light and switched power.
Stubbie
Old 01-04-2014, 01:07 PM   #10
UAW SKILLED TRADES
Stubbie's Avatar
If you determined that the other 3 way does not switch the power on that black wire then you have constant hot and can do what you want. Do you have your instructions to the combination switch?
Stubbie
Old 01-04-2014, 01:27 PM   #11
UAW SKILLED TRADES
Stubbie's Avatar
Here is a link that should help you
http://www.google.com/url?sa=t&rct=j...58187178,d.b2I
Stubbie
Old 01-04-2014, 01:50 PM   #12
Rewards Points: 4,784
I'm no expert but I'm going to go out on a limb and say you have a neutral to tie to.
jeffnc is offline   Reply With Quote
Old 01-04-2014, 01:59 PM   #13
Rewards Points: 150
Bingo! Got it, thanks guys.
Jeff, where in NC are you?
Old 01-04-2014, 02:02 PM   #14
UAW SKILLED TRADES
Stubbie's Avatar
Nice to hear it has worked out for you. Looks like an awful nice cabinet to put mud in ....LOL
Stubbie
Old 01-04-2014, 02:08 PM   #15
Rewards Points: 150
Thanks, it still needs to be caulked, sanded, and painted. The boss (wife) loves it so far and you know how it goes, happy wife happy life.
Cloth wiring switch to Romex DiegoJames Electrical 0 07-09-2013 09:15 PM
Simple question regarding Wall Switch wiring kebrein Electrical 6 11-25-2011 08:54 PM
Wiring an Intermatic Wall Timer in a three way switch aitutaki98 Electrical 6 07-23-2011 12:43 PM
Fitting dimmer switch to old electrical wiring hugomax69 Electrical 0 01-29-2010 08:40 PM
Switch on K&T wiring - OK to pigtail? fdmillion Electrical 4 01-27-2010 10:15 AM
