Need Some Help Installing A Light Fixture - Electrical - DIY Chatroom Home Improvement Forum
Old 12-08-2012, 06:29 PM   #1
Rewards Points: 89
Need some help installing a light fixture
Hi,
I am installing my first light fixture. I could use some guidance about how to attach the wires. Specifically:
1. The first photo is of the wires from the light itself. Notice how they are frayed. How should I go about connecting these into the wire nuts, considering the amount of fraying?
2. The next photos are of the electrical box where the light will be installed. I am wondering how exactly I should connect the ground wire. Also, what are those two wires in the middle? What do I do with them?
3. Finally, here is the light switch. Notice that the white wires are not connected to the switch itself. Does that mean I should leave the white wires alone when installing the light?
Thanks!!
Need some help installing a light fixture-100_1541.jpg   Need some help installing a light fixture-100_1543.jpg   Need some help installing a light fixture-100_1544.jpg   Need some help installing a light fixture-100_1547.jpg   Need some help installing a light fixture-100_1548.jpg
19mquinn79 is offline   Reply With Quote
Old 12-08-2012, 11:13 PM   #2
Originally Posted by 19mquinn79
Hi,
Thanks!!
Grab the wires and twist the ends. That should fix the fraying.
It's very common for boxes to have junctions of other things in them. They could have power feeding the outlets passing through.
Switches allow power to pass through to the other wire. The hot wires need to be hooked to the switch but not the neutral or ground. Leave the white wires alone...
mbryan is offline   Reply With Quote
Old 12-09-2012, 06:34 AM   #3
Lic Elect/Inspector/CPO
After making sure power is off, twist ends of wires and that will take care of the fraying.
At the ceiling box the ground wire can be connected to the ground screw on the fixture mounting bracket. If no bracket than remove green clip from box tie all ground together, pigtail a piece of ground wire and install wirenut, than reinstall green clip with ground wire.
The white {neutral] wire will connected to the white wire from the fixture and the white with black tape black will be connected to fixture black wire.
The switch wires would be left alone.
NJMarine is offline   Reply With Quote
Old 12-09-2012, 11:19 AM   #4
Rewards Points: 89
thanks!! just so i'm sure, you're saying the two "outer" pairs of wires in the 3rd picture, the red and black ones, should not be connected to the wires from the light? i should leave them alone?
Old 12-09-2012, 11:31 AM   #5
Rewards Points: 2,516
The white wire that is taped black at the light fixture is part of the switch loop. Meaning when the switch is turned on, the white wire taped black becomes HOT.
hammerlane is offline   Reply With Quote
Old 12-09-2012, 01:10 PM   #6
At the switch if all 3 wires are connected to switch, hook them up to new switch the same way. The wire for power in or power to light goes on the common
Old 12-09-2012, 01:10 PM   #7
Old 12-09-2012, 01:10 PM   #8
Problems with installing new ceiling light. jcpiebald Electrical 3 12-29-2011 12:14 PM
installing light fixture in old box annie68164 Electrical 5 09-03-2011 10:08 PM
hi im new! need a little help with installing light fixture! mrogers00000 Electrical 17 07-03-2011 11:39 PM
Installing a new light fixture brokenhammer Electrical 1 01-10-2009 07:14 PM
installing a light fixture on a switch controlled outlet Unregistered Electrical 1 02-24-2004 10:51 PM
