Need Some Help... - Electrical - DIY Chatroom Home Improvement Forum
Old 05-27-2008, 06:34 PM   #1
Need some help...
Hi, I just registered. I figured this would be the perfect place to ask my question. I am trying to install an Intermatic GM40 time switch. I have an ice machine at my fishing camp, so to save electricity, I purchased this timer to control the power supply so that the machine comes on Thursday nights and goes off Sunday afternoons. I'm certainly no electrician, so please excuse my ignorance on this. I have mounted the timer next to my ice machine. The timer will only control one outlet (115). So, the object here is simple. I'm taking one wire feed, connecting the timer, then running a wire feed to the outlet to be controlled. As you will see from my pictures below, there is a buss at the bottom, and a wiring diagram. However, I don't have the capability to read this diagram. It is embarrasing, because it seems that it should be simple. Please review the following pictures and let me know where to feed the hot and neitral wires into the buss. Then, where I should tie in my outlet. Thanks for the help. I apprieciate it.
TNSmith is offline   Reply With Quote
Old 05-27-2008, 06:38 PM   #2
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
The wire you're feeding it, take it to the common screw ( a jumper), the wire you want to feed your ice machine receptacle run that off of the NO (normally open) screw, be sure to feed a neutral to the time clock or the timer mottor wont work.
wirenut1110 is offline   Reply With Quote
Old 05-27-2008, 06:40 PM   #3
Thanks! I forgot to mention, the unit came with a jumper going from L1 to the common. Is this the jumper you're referring to?
Old 05-27-2008, 06:42 PM   #4
Rewards Points: 510
yes so just feed the time clock on L1(hot) and L2 neutral and the hot to your receptacle will come off of the NO contact (screw)
Old 05-27-2008, 06:45 PM   #5
Rewards Points: 510
Also, make sure this time clock is rated to handle the load of the ice machine.
Old 05-27-2008, 06:45 PM   #6
And I'm guessing the neutral that feeds my outlet will come out of the L2 as well? Looks like the diagram combines them. Is this correct? Again, thanks
Old 05-27-2008, 06:46 PM   #7
Good advice... I have verified that it will handle the load.
Old 05-27-2008, 06:47 PM   #8
Rewards Points: 510
yes, neutrals together whether you pigtail them or use the terminals
Old 05-27-2008, 06:49 PM   #9
Thanks so much wirenut... your help is exactly what I needed. Thanks again and take care
Old 05-28-2008, 07:25 PM   #10
adding 2 can lites from the same switch
mpreston35 is offline   Reply With Quote
Old 06-01-2008, 12:52 PM   #11
Well, the switch works great. Just wanted to say thanks again.
Old 06-01-2008, 12:55 PM   #12
Rewards Points: 510
No problem
