Need Some Electrical Trouble Shooting Help. - Electrical - DIY Chatroom Home Improvement Forum
Old 03-07-2010, 02:02 PM   #1
Need some electrical trouble shooting help.
So I know how to do minor electric work, and a friend had me fix a light that wasn't working. The base where the lightbulb screws in would randomly pick up on my chirper when I jiggled it around. I cut the power, checked it was dead on my chirper, and cut out the base and put the new one it. Put the power back on and it works...
While making sure everything was nice safe and bolting the light back up I somehow got my chirper to go off from touching the housing... I then checked the greenfield conduit (maybe a half-inch diameter) that was coming out of the metal light housing and going into a second room to supply an exit-sign, and all up to the exit-sign it chirped... The light switch box also chirped (which isn't connected at all to the light or the conduit/exit sign)...
Even when I flip the switch to off, everything chirps...
I'm curious as to what you guys think... It's an old house, with ****ty looking cable. I also noticed there was not a ground to be attached for the light switch...
From touching the light housing, and the light switch box, and the exit sign, I didn't get any kind of shock. I also noticed my screwdriver was somewhat magnetic after finishing up the job...
Hope someone can help me get to the bottom of this.
Thanks in advance,
-Dan
Dannmann99 is offline   Reply With Quote
Old 03-07-2010, 02:13 PM   #2
Master Electrician
Rewards Points: 3,870
Voltage detectors are notorious for picking up stray voltages and static electricity. Even high quality high-impedance voltmeters will do the same. Best guess would be there is nothinng wrong at all.
brric is offline   Reply With Quote
Old 03-07-2010, 04:04 PM   #3
Idiot Emeritus
Rewards Points: 1,492
Those 'chirpers' are nick-named 'deathsticks'.
As stated above, they'll give false readings frequently. They'll chirp on stuff that's dead, and sometimes make no noise at all on a hot circuit.
Rob
micromind is offline   Reply With Quote
Old 03-07-2010, 06:47 PM   #4
Electrical Contractor
kbsparky's Avatar
I use my "chirper" to mystify kids by rubbing it on their sleeve --- it will chirp with normal static electricity.
You have to get a steady chirp with one of those to determine if you have a constant power source -- even then it can give false positive readings from a line with inductive voltage on it ...
-KB
Help troubleshooting furnace problem robert_ HVAC 21 02-15-2012 08:04 AM
Totaline thermostat trouble shooting Goldwing93 HVAC 3 07-30-2009 10:35 PM
Trouble Shooting a Carrier 9200 Weathermaker Furnace JoeDell HVAC 4 01-08-2009 04:07 PM
electrical trouble shooting - how much does it cost? electricpro Electrical 30 09-07-2007 01:26 PM
Arc Fault Trouble Shooting michael byrnes Electrical 4 06-13-2007 04:24 PM
