Need Some Electrical Circuit Advice - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 11-26-2008, 05:08 PM   #16
An old Tradesmen
Rewards Points: 6,464
Missed that its gas.
Old 11-26-2008, 08:33 PM   #17
dgbehrends's Avatar
Rewards Points: 150
Send a message via Yahoo to dgbehrends
I was doing some reading on combination AFCI circuit breakers and it looks like they are going to be code for all new construction areas of a home except for kitchens. I took this free online course.
http://www.syberworks.com/squared/co...-elearning.htm
I'm going to return my standard breakers and buy some the combination arc faults. Does anyone here have any opinions on the combination arc fault breakers?
D in MN
dgbehrends is offline   Reply With Quote
Old 11-26-2008, 08:43 PM   #18
DIY'er
jamiedolan's Avatar
Rewards Points: 1,024
They are really expensive. imo, They appear to be of fairly limited value if your wiring is done properly with good connections. I personally am not inclined to install them unless required to do so.
Jamie
jamiedolan is offline   Reply With Quote
Old 11-26-2008, 09:41 PM   #19
Rewards Points: 2,350
I think they are just a way to sell breakers. In my opinion, they are virtually useless, except a very narrow range of circumstances.
Old 11-27-2008, 01:55 AM   #20
dgbehrends's Avatar
Rewards Points: 150
Jamie
your right they are really expensive $40 for a 20amp
hmmm maybe I won't buy them, however doesn't the 2008 NEC code require them?
D in MN
Old 11-27-2008, 09:55 AM   #21
Yes, if your state has adopted the entirety of the 2008 NEC. Some states have adopted it, others have not, and yet other have only adopted pieces. So check with your inspector.
Old 11-29-2008, 12:16 AM   #22
Rewards Points: 150
alls i know is that those 1500 watt space heaters almost need a dedicated circuit of their own. i am remoldeling a house and i run everything off of one circuit. if there's anything else plugged in along with the heater the breaker trips (with the exception of a 40 watt light fixture). otherwise without the heater i can run anything (radio (usually playing old psych cd's like can, almendra, the seeds, or some jazz like sun rah or john coltrane, funkadelic, davie allen and the arrows etc) cirular saw, table saw, compressor, what kind of music does everyone listen to here? i can;t work without it, i get too lonely i almost kill myslef.
drewhart is offline   Reply With Quote
Old 11-29-2008, 08:50 AM   #23
Why, oh, why, would you put everything on one circuit? That's what they did in 1920. I personally like to have every room to a circuit, generally. I sometimes put two bedrooms on a circuit.
Jazz pulls too many amps..
Old 11-29-2008, 10:05 AM   #24
Rewards Points: 150
well i am remodeling this house and hadn't finished the wiring yet. so i ran an extension cord up from the basement to a power strip.
Old 01-15-2009, 12:57 PM   #25
dgbehrends's Avatar
Rewards Points: 150
Follow up Project completed
Thanks to everyone for their input.
Here is the circuit diagram that I submitted for inspection.
http://img106.imageshack.us/my.php?i...diagramps2.pdf
I wired everything up including the 3 combination AFCI circuit breakers and passed my inspection. MN code follows NEC 2008 code exactly so I needed to spend the extra money and get the combo circuit breakers.
D in MN
Just for fun Andy in ATL Electrical 56 10-20-2009 10:33 AM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
Max amps allowed - electrician advice needed Des Electrical 27 06-05-2008 11:31 PM
Electrical Advice Caution!!! Mike Swearingen Electrical 12 03-05-2008 12:51 PM
Circuit breaker panel - Advice needed justtired Electrical 15 12-13-2007 06:55 AM
