Old 02-05-2013, 05:16 PM   #1
Need some clarification on electircal oven/microwave combo install
I'm planning on buying a 30" MMW9730A Maytag oven microwave combo. The install instructions seem generic about the amperage and wiring stating it's a 240vac 5520w at 30.5amps. Currently I have a 3 wire (with a 4th ground) 10g wire going to 2 phase 30amp breakers. If my math is correct 5520w shouldn't be pulling more than 24amps which would fall in the %80 range. So why do they state it's pulling 30.5 amps? I've currently have the walls out and wondering if I need to spend the money to get this upgraded to 8g/40amp breakers or will the current wiring work?
devslashnull is offline   Reply With Quote
Old 02-05-2013, 05:18 PM   #2
joed's Avatar
Does the unit have a plug? If it does then you need to match the circuit to the plug installed on the unit.
Do not PM with questions that can be asked in a forum. I will not respond.
Old 02-05-2013, 05:24 PM   #3
There was a plug on it, I removed it to inspect the wires, the instructions for the new oven calls for it to be wired to a j-box.
New cabinets, subfloor & install height Ohming Building & Construction 10 03-02-2011 03:18 PM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 10:49 AM
Diagonal Hardwood Install Advice JDeFuria Flooring 7 06-29-2009 04:35 PM
wall microwave oven combo install Jaymross@mac.com Carpentry 3 10-08-2008 06:00 PM
best bit(s) to do electircal install rtoni Electrical 13 11-26-2007 09:24 AM
