Need Some Advice, Quickly! - Electrical - DIY Chatroom Home Improvement Forum
Old 11-19-2011, 08:57 AM   #1
Rewards Points: 174
need some advice, quickly!
I was all ready to replace my 2 gang switch box with a three gang making room for another switch. I'm now realizing that my 2 gang box is metal and the new one I bought is plastic. Can I ground all three switches by pig tailing all three grounds together and grounding only on the new switch/grounding screw?
tb582 is offline   Reply With Quote
Old 11-19-2011, 09:08 AM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,824
If you are going to re-use the old switches, yes. But WHY would you?
The Following User Says Thank You to Speedy Petey For This Useful Post:
gregzoll (11-19-2011)
Old 11-19-2011, 09:12 AM   #3
Civil Engineer
Rewards Points: 4,520
The actual ground is the (typically bare) copper wire that travels from the panel to the box, generally in the form of two conductor cable plus ground. The grounding screw on the switch, and the grounding screw on the old metal box, are there to provide a convenient way to ground the switch or the box. If you lack a grounding wire from the panel, you cannot achieve a ground no matter how you connect the devices. I cannot tell from your photo if you have a grounding wire coming from the box.
If you do, you can pigtail the grounds from your devices to the grounding wire, adding a pigtail for each switch and outlet. I believe that it is not necessary to ground a plastic box, perhaps one of the electricians in the forum can weigh in on that question.
Old 11-19-2011, 09:12 AM   #4
Rewards Points: 174
I'm not planning on re using the old switches, but on the current ones there's no ground, and I'm not replacing the wire for those other switches so I don't think they have ground.
Old 11-19-2011, 09:15 AM   #5
Rewards Points: 174
Better in this pic?
Old 11-19-2011, 09:37 AM   #6
Rewards Points: 1,528
Your old cable seems to have ground wires; they are the bare copper ones twisted together. TURN OFF POWER TO ALL WIRES IN THE BOX.
1. Make a drawing of which wires go to which switch before you take out the old ones. Perhaps label each wire with masking tape and number them.
2. Put in new box
3. Run cables into box; if plastic, extend the ground wires via short pieces of ground wire to the ground screw on the new switches. If metal, do the same but also run a ground to the box itself. Should be a green grounding screw for this.
4. Put wires on new switches following your wiring diagram from step 1.
bob22 is offline   Reply With Quote
Old 11-19-2011, 10:19 AM   #7
Boston Fan, get over it
Toofarfromfenwa's Avatar
You do not, and cannot, ground a plastic box.
Toofarfromfenwa is offline   Reply With Quote
Old 11-20-2011, 01:20 PM   #8
Rewards Points: 174
2. Put in new box
Kinda what I did except without all the documentation . Now I cant get things working they way they should.
I have two switches, one should control the hall light the other the outside light. There also appears to be a receptical on the same circuit. I can get it where one switch controls the hall light but then the other controls the outside light and the recpetical! I'm driving myself mad here! any advice as to how I can fix?
Old 11-20-2011, 02:46 PM   #9
Licensed electrician
Rewards Points: 1,020
You could add three tails off the grounds and connect one to each switch.
Toofarfromfenwa (11-20-2011)
Drywall ceiling: Water Damage, looking for advice dawho1 Building & Construction 11 09-13-2010 11:05 AM
looking for Serious advice and Help on Insulation bfan781 Building & Construction 6 05-19-2010 12:02 PM
helpful advice NHMaster Off Topic 0 05-12-2010 05:47 PM
DIY Advice Seeker - late 1970 seventies knockdown texture onegative Drywall & Plaster 1 04-22-2010 09:40 AM
Electrical Advice Caution!!! Mike Swearingen Electrical 12 03-05-2008 12:51 PM
