Need A Single Phase 220v Transformer - Electrical - DIY Chatroom Home Improvement Forum
Old 02-28-2011, 03:13 PM   #1
KBK
Need a single phase 220v transformer
I have a grain mill with a 220v single phase motor. I'd like to use this in the USA where the standard voltage is 110v or 240v split phase. Since I need a 220v primary line, a neutral and ground (3 wire), what type of transformers I should be looking for. I bought a heavy duty transformer online but soon found out that that darn thing gives out only split phase 220v (i.e., two hot 110V). Thanks in advance.
KBK is offline   Reply With Quote
Old 02-28-2011, 03:17 PM   #2
Scared Electrician
Saturday Cowboy's Avatar
the numbers 220 230 and 240 are all used interchangeably to refer to the same voltage. no transformer needed. split phase and single phase are the ~same thing
Ragged Trousered Philanthropist
Please follow the code - its there for your safety no matter how inconvenient.
Saturday Cowboy is offline   Reply With Quote
The Following User Says Thank You to Saturday Cowboy For This Useful Post:
KBK (03-04-2011)
Old 02-28-2011, 05:06 PM   #3
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
In the US, you would use the 2 hot legs and not the neutral and then the ground to get 240 single phase (used to be 220 years ago).
We toss in a center tap to get out 120 volt supply.
The Following User Says Thank You to nap For This Useful Post:
KBK (03-04-2011)
Converting 3 phase equipment to single phase /VFD? lightison Electrical 7 01-04-2011 03:14 PM
Wiring Single Phase through 3 Phase socket tonyr417 Electrical 10 10-26-2010 09:09 PM
Want to add a single phase Subpanel to three Phase Main meglomachinist Electrical 19 09-10-2009 03:46 PM
How to power a 120/240 volt 3 phase oven in a building with 120/240 volt single phase wantsomegetsome Electrical 9 05-04-2009 10:49 AM
Wiring a single pole switch into a 220v circuit rlmorgan Electrical 38 10-15-2008 07:59 PM
