Need Similar Switch/remote Lutron IR Maestro - Electrical - DIY Chatroom Home Improvement Forum
Old 12-29-2013, 04:13 PM   #1
Need similar switch/remote Lutron IR Maestro
I already have this setup in my living room:
http://www.dimmers.net/fanlight.asp
This has been a wonderful purchase, we can not live without this setup, however for our bedroom reno this won't work. I'm looking for a similar setup but with a rocker switch instead.
Walking in and out a bedroom the tap switches are not easy to use or as quick. You can't whack the tap switch like on a decora rocker.
I can't find anything that solves this problem. Worst case we'll buy another Lutron.
*Please note the distinction with this remote/switch setup is the remote controls the wall switch which controls the light/fan. Those cheap remotes you see at the big box stores won't work like this.
Thanks for any help.
barbarino351 is offline   Reply With Quote
Old 12-30-2013, 07:46 AM   #2
Rewards Points: 348
I would disagree. Every switch/dimmer in our house is a Lutron Maestro. Now ours are the full sized ones which may make a difference. The cool thing about them is that they are a toggle, so if they are on, just whacking it at the top, middle or bottom turns it off and vice versa.
If you are doing a full bedroom reno, take a look at the Radio RA 2 line. Gives you more control than from the handheld remote, plus gives you the base to automate all the lighting in your house.
herdfan is offline   Reply With Quote
Lutron Maestro Dimmer Question tommyxv Electrical 2 08-21-2013 10:33 PM
LED lights & Lutron Maestro dimmer JulieMor Electrical 11 04-04-2013 03:14 PM
Lutron maestro IR Dimmers Multiple if possible???? Drewex Electrical 20 08-27-2012 11:45 AM
Help with Lutron Maestro IR dimmers jkr77 Electrical 5 02-28-2011 08:38 AM
Lutron Satin Snow compares to Cooper Satin white tomas21 Electrical 2 09-16-2008 03:21 PM
