Old 08-26-2006, 10:50 AM   #1
Need to replace Pushmatic panel?
I'm going to have the basement finished, and we're talking electrical. Contractor says the two open slots in the panel will be OK.
However, electrician friend says the Pushmatic panel should be replaced for a couple reasons: we won't be able to find new circuit breakers for the open slots, one of the breakers is already double-tapped so I will only really have one open slot to work with, and there is still the aluminum wire from the meter.
I *think* this panel is original (1965) but can't tell. Do I really need to replace the panel? If there's a decent chance of electrical problems with the Pushmatic, I'll replace it.
THANKS!
ohfreddie is offline   Reply With Quote
Old 08-27-2006, 05:25 PM   #2
World famous jerk.
The Pushmatic panel is one of my all time favorites. It was one of the only residential panels with bolt on breakers, which eliminates a common failure point. They only lasted in production until the early 80's. They were hard for older folks to press in and out, and sometime if you didn't press them hard enough, you might have thought the circuit was off, when it actually indicates 'on'. In any event, they always tripped when they were supposed to. There is some urban myth to the contrary, but that was never the case.
Pushmatic was called several different brands as they were bought out over the years. Pushmatic, Bulldog, ITE/Pushmatic, Seimens/Pushmatic. I'm about 99% sure that Seimens still has them, because I still get Pushmatic breakers from my Seimens dealer.
You can replace that panel if you want to, but I see no overwhelming reason to do so. Add a subpanel of another more common brand if you feel you need to, using the last two spaces in your panel to feed that subpanel.
Yes, the Pushmatic breakers might be a litle harder to source and a little bit more expensive than the typical Square D breaker, but most folks can deal with that. I wouldn't hold it against you if you did want to replace that panel, but unless it's suffered damage of some sort, there's just no clear reason to do so.
mdshunk is offline   Reply With Quote
More On This Topic
Learn how to remove side trim board to remove the siding on you house from a professional contractor in this free DIY home improvement video. Read More »
Replacing Painted Ceiling Panels
Replacing Painted Ceiling Panels by eHow Home & Garden Editor
Once ceiling panels are dry, it's alright to reassemble them. Replace a living room's ceiling panels with tips and techniques from a professional painting contractor in this free video on home decor. Read More »
How Car Panels are Replaced
How Car Panels are Replaced by eHow Cars Editor
Replacing car panels--how to weld, where to clamp and what to caulk--is explained by our expert in this free auto-body repair video. Read More »
Replace a motorcycle’s side panels when changing out the bike’s air filter; learn how using the expert advice found on this free DIY motorcycle-maintenance video. Read More »
Replace the inner panel of a wrecked car by attaching the new panel to the factory frame seams, not in segments; our expert tells you how in this free auto-repair video. Read More »
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 08:40 PM
12v diff between ground and neutral at panel am9518 Electrical 7 02-25-2008 07:28 PM
Outdoor breaker panel questions lhoney2 Electrical 12 07-19-2007 06:44 PM
Splice in Neutral to Panel - OK or Not? allpraisebob Electrical 4 08-12-2006 06:54 AM
Adding new circuit breakers to 100 amp sub panel DrP Electrical 8 05-25-2006 11:05 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
