Need To Replace A Main Breaker, Which One Is Correct? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-23-2012, 11:26 PM   #16
" Euro " electrician
frenchelectrican's Avatar
There is one tip which I do from time to time but not always work on this type of panel but there is couple breaker on left side of the main breaker ( SVP kill the main first before you do this part ) and yank two or three breaker and see how the bussbar look like if kinda burnted or smell like it was burnted then I will recomend that the panel to be replaced.
I know few of the guys recomened that the main breaker to be replace by whole panel due there are some reason due if the lugs were overheated and if you installed the new main breaker on the exsting bussbar tab which it did show sign of overheat and try to clean it and installed it back well.,, tell you the truth it will fail again.
So that kinda a judgement call and by the way is this panel is outdoor location ??
Merci,
Marc
Old 09-23-2012, 11:39 PM   #17
Rewards Points: 610
OK T60..you seem to be very indignant even though you are the one asking for advice..maybe you should have explained about the age of the panel ..up front..AND sown a picture of the whole panel to boot OR just take the poco's advice and not bother with this forum.IMHO .people shouldn't have to apologize to you for your short temperament
techpappy is offline   Reply With Quote
Old 09-24-2012, 12:54 AM   #18
t60
Rewards Points: 125
Merci,
Marc
Thanks for the info -- he had pulled the breakers yesterday and said the panel looks great, just the main breaker needs to be replaced.
Calm down.
I asked a very basic question on a breaker and was told "replace the entire panel" without reason. I wasn't asking to troubleshoot a problem, just trying to find out the difference between two breakers I saw. I'm sure most people would be frustrated, and it's water under the bridge now.
You shouldn't feel compelled to respond in my thread, especially when you don't provide any pertinent information.
t60 is offline   Reply With Quote
Old 09-24-2012, 08:04 PM   #19
deverson's Avatar
Rewards Points: 77
I do see a 20 space Murray panel for 55.00 at Lowes
Item #: 71774 | Model #: LC2040B1100
deverson is offline   Reply With Quote
Old 09-24-2012, 10:29 PM   #20
t60
Rewards Points: 125
Thanks for the info -- I was just about to buy a new main breaker, but curiosity got me and the panel I have is a Murray "JA1020B1100F" which is $45 here at Home Depot. I may just buy that instead and replace the panel after all! It doesn't look that hard to replace, I would probably spend most of my time wiring neutrals/grounds in the busbar neatly and putting the breaker wires back together.
Worst case it comes with the main breaker which is $30, so I figure $15 more and I can get the entire panel with the breaker installed instead! I retract my previous statements about replacing the panel, as I had no idea it would be so close in price. Sorry deverson.
Old 09-24-2012, 11:46 PM   #21
Electrical Contractor
jbfan's Avatar
Rewards Points: 254
If it is the same panel, you can remove the guts and place them into the can without removing the can.
The Following 2 Users Say Thank You to jbfan For This Useful Post:
frenchelectrican (09-25-2012), t60 (09-25-2012)
Old 09-25-2012, 12:31 AM   #22
Generally this is quicker than try to rip the whole can out.
Few of us done like that once a while.
Merci,
Marc
The Following User Says Thank You to frenchelectrican For This Useful Post:
t60 (09-25-2012)
Old 09-25-2012, 12:46 AM   #23
t60
Rewards Points: 125
Thank you -- I recall the electrician I hired to replace the panel 3 years ago did this. I wondered why the can was still looking so old even after the replacement. I looked at my receipt he gave me and cannot believe he charged me $280 for the work. It only took him 30 minutes and a $50 part; he didn't even replace the main breaker
Old 09-25-2012, 12:55 AM   #24
Sérieux ?
Most homes/commercal locations generally I will replace the whole thing but if the tub or can is enbedded in concrete then it is differnt story.
Merci,
Marc
Old 09-25-2012, 07:42 AM   #25
jbfan's Avatar
Rewards Points: 254
OK, now replace the panel
As long as the replament parts have a main breaker,then you can replace the guts, or go all out and replace the panel.
Old 09-26-2012, 06:30 PM   #26
t60
Rewards Points: 125
Quick question -- do the breakers need dielectric grease before installing them onto the new "guts"? I see some on existing breakers, but not sure if it's really needed.This panel is outside of my house..
Old 09-26-2012, 07:01 PM   #27
Oso954's Avatar
Rewards Points: 772
Dielectric grease is insulating, non-dielectric is conductive.
You didn't mention a heavy ocean fog, which is applicable to your question.
My input would be that a little non-dielectric in the right places can't hurt, but too much in the wrong places can.
Oso954 is offline   Reply With Quote
Old 09-26-2012, 08:26 PM   #28
t60
Rewards Points: 125
You mention heavy ocean fog, which is actually applicable in my situation. I live in Pacifica, CA where it's foggy 80% of the year. I'll see if I can find the grease easily, if not, I'll just skip it since it doesn't sound like it's needed. Just want to prevent the same issue from occurring if I can.
Old 09-26-2012, 08:32 PM   #29
jbfan's Avatar
Rewards Points: 254
Do not use any grease. Add nothing the dosen't come on the breaker when you buy it.
Changing a breaker. Turn main power off first? noone Electrical 18 11-15-2011 08:08 PM
Main Circuit Breaker Question vladmir1111 Electrical 2 08-20-2011 09:15 PM
Main Breaker Melting rubberhead Off Topic 8 03-16-2011 08:50 PM
Main house breaker keeps tripping cosmicmah Electrical 20 01-22-2008 01:36 AM
Main Breaker Trips Repeatedly kkf Electrical 7 06-18-2007 05:31 PM
