Need To Replace Can Light With Standard Light - Electrical - DIY Chatroom Home Improvement Forum
Old 02-25-2008, 01:03 PM   #1
Question
Need to replace can light with standard light
We have a recessed light fixture in the bathroom that the wife wants me to replace with a small chandilier she purchased. The new light has all the standard h/w to hang it from a standard ceiling light box. Since the existing recessed light and can are in the ceiling, and the hole for it is much larger than the normal ceiling light box, I'm looking for a solution to replacing the light properly. I know I can go Rambo and just open the ceiling enough to rip out the can and put in the correct size ceiling box for the new light size and weight (though it is a small fixture). I am curious if there is some sort of conversion kit to replace the recessed light. I will probable put one of those decorative ceiling medallian's up to cover the larger hole.
Thanks!
Woodcutter is offline   Reply With Quote
Old 02-25-2008, 01:38 PM   #2
Licensed Pro
Take this for what it is worth, as I have never used it before (I'm more the Rambo type ), but I did see on the shelf at lowes, a kit for doing just what you want to do. It is in their Intelitech store brand, located with the recessed fixtures. It might be worth a look.
Old 02-25-2008, 02:24 PM   #3
Thanks HouseHelper. I'll look for that kit @ Lowes.
I like your tag line!
Old 02-29-2008, 08:06 AM   #4
Thumbs up
Househelper - I bought that kit @ Lowes and installed it last evening. Worked great! And if I ever want to change it back to a spot, it'll take 5 minutes or less. Thanks for the tip.
Hall light worked before installing a new light fixture in bathroom jcfan7 Electrical 40 02-23-2008 10:46 AM
Trying to replace wall mounted light fixture jtm2300 Electrical 4 08-03-2007 10:44 PM
Part of a ceiling fan light fixture needs help...please g5729 Electrical 1 06-17-2007 07:22 AM
Hot Light Outlets Materials Guru Electrical 5 07-31-2006 08:11 PM
Replacing light killed downstream outlets, totally stuck amissner Electrical 5 07-13-2006 07:02 AM
