Need To Replace - Electrical - DIY Chatroom Home Improvement Forum
Old 04-14-2012, 10:36 AM   #1
Rewards Points: 27
Need to replace
Can someone tell me how to replace one of these with a programable thermostat
woodenSpoon is offline   Reply With Quote
Old 04-14-2012, 10:43 AM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Buy a new one. Remove the old one from the wall. Mark the wires and what terminal they went to. Put the wires on the corresponding terminals of the new stat. Mount it to the wall.
The Following 4 Users Say Thank You to k_buz For This Useful Post:
gregzoll (04-14-2012), PaliBob (04-15-2012), plummen (04-16-2012), Speedy Petey (04-15-2012)
Old 04-14-2012, 10:57 AM   #3
Licensed electrician
Rewards Points: 1,788
The terminals should be labeled with single letters to designate the colors ie R=red, W=white etc.
Old 04-14-2012, 11:50 AM   #4
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
Be sure to shut off power/breaker before removing wires.
sublime2 is offline   Reply With Quote
Old 04-14-2012, 12:14 PM   #5
Missouri Bound's Avatar
Regardless of how you proceed, this it the most important step.
Do you want it your way or the right way?
Old 04-14-2012, 12:15 PM   #6
Rewards Points: 150
Your current thermostat is for heating and cooling. Make sure the new thermostat is for heating and cooling, some are for heat only.
goosebarry is offline   Reply With Quote
Old 04-14-2012, 12:43 PM   #7
And based on lessons learned in another thread, check to see if the new has a switch for gas or electric heat and set it appropriately.
Evstarr is offline   Reply With Quote
Old 04-15-2012, 01:08 AM   #8
Just a DIY guy
Could be a jumper on the stat board rather than a switch. See the instructions.
M3 Pete is offline   Reply With Quote
Old 04-15-2012, 01:11 AM   #9
Just a DIY guy
Ok I'll admit I have never done this. How do you know what breaker? I thought stats were ultra low voltage, no?
Old 04-15-2012, 04:27 AM   #10
JOATMON
ddawg16's Avatar
Rewards Points: 1,976
The existing t-stat is basically a thermostatic switch (bi-metal sensor with mecury switch). When the mecury makes contact...it turns on the AC or heat depending on the switches.
You will have a 24Vac source....on older systems it might be a transformer stuck on the outside of duplex box in some closet or in the garage. On newer units, the 24Vac is in the HVAC unit.
If the 24Vac comes from the HVAC...just unplug the unit. If it comes from a seperate transformer....you will have to keep turning off breakers until you find it. When in doubt...turn off the main. (good reason to have all of your breakers mapped)
When you buy the new t-stat....the directions will actually be very good.
Make sure you make not of which wire goes where on the old t-stat before you unplug it.
Depending on when your old one was installed...there is a chance that it uses standard wire colors. Once you read the instructions on the new t-stat, you will understand.
Old 04-16-2012, 01:39 AM   #11
Just a DIY guy
Let me clarify, I've never switched off the power when changing a stat. Let me ask the real question. How dangerous is the 24Vac? (assuming I'm NOT holding a wet ground rod in my other hand). I've always heard it's the amps that kill you, but I'm not even sure that's accurate. Is 24volts hazardous?
The Following User Says Thank You to M3 Pete For This Useful Post:
Old 04-16-2012, 02:47 AM   #12
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
You could just shut the switch off on side of furnace,although it looks like a plain old 24v stat to me its not going to bite ya.
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 04-16-2012, 07:07 AM   #13
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
Killing the power is more of a safeguard for the equipment then it is for the person.
Old 04-16-2012, 08:17 AM   #14
plummen's Avatar
About the worst thing youre going to do is have a call for heat or cooling if you bump another wire against the red,wont hurt anything
Old 04-16-2012, 08:22 AM   #15
Rewards Points: 3,256
I was thinking more along the lines of the electronics in a digital thermo....but that's just me.
zappa is offline   Reply With Quote
The Following User Says Thank You to zappa For This Useful Post:
sublime2 (04-16-2012)
Replace or sister floor joists WillK Building & Construction 6 03-09-2011 08:55 PM
Must I replace the coil when I replace the outside condenser unit? plichtenstein HVAC 5 08-24-2010 02:41 PM
When to replace a furnace? stanlam HVAC 3 07-20-2010 07:21 PM
Need Advice ASAP. New home, seller is paying to replace roof elpa Roofing/Siding 4 02-18-2010 07:03 PM
Replace door sill = Need new door? NNJGUY Carpentry 23 09-01-2009 01:54 PM
