Need A Remote For Whole House Fan - Electrical - DIY Chatroom Home Improvement Forum
Old 07-31-2006, 11:10 PM   #1
need a remote for whole house fan
Does any body know if a regular remote setup for a ceiling fan would work for a whole house fan.
I seen some remote setups that a person can add to a ceiling fan at home depot.
I just want to run wiring to the whole house fan and not have to worrie about wiring in a switch.
Thanks Doug
Doug Crf is offline   Reply With Quote
Old 08-01-2006, 05:21 AM   #2
If the part of the switch that installs in the fan is rated for the proper hp then it sould work, but since this would not be an OEM setup you would have no warentee.
Another option is X-10 modules available at radio shack. (I am not endorcing one store this is just an example)
With these you install a recieving module in the attic and a transmitting module anywhere in the house that you want. Your electrical lines carry the signal.
jwhite is offline   Reply With Quote
Old 02-18-2007, 01:34 AM   #3
wireless switches...
The XXXX switches will work for this, I know this post is a little old but this is new technology...
Last edited by AtlanticWBConst.; 02-06-2008 at 07:25 AM. Reason: Advertising Information removed
tdavis is offline   Reply With Quote
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
replumbing an old house simonfrog Plumbing 7 01-30-2012 05:45 AM
200 Amp service really needed for a 830 sq ft house? overkill? alexz Electrical 7 11-16-2009 06:54 PM
Re-siding house jdig Building & Construction 5 04-10-2007 10:15 AM
Brick and block house footer question. ourzoo Building & Construction 2 07-01-2006 03:57 PM
