-   -   Need recommendation of non-contact voltage tester (http://www.diychatroom.com/f18/need-recommendation-non-contact-voltage-tester-144477/)
miamicuse 05-21-2012 08:35 PM
3 Attachment(s)
I used to have a non-contact voltage tester that worked fairly well. I got it from Builders Square (back when they were still in business). Over the years it dropped a few times and finally it stopped working.
Last week I went to Home Depot and picked up a new one, real cheap I think like $6.99. The problem is I can't really use it. It seem to be real sensitive and when I insert the tester into a junction box it beeps when there is nothing within a two inch radius.
My most typical application is to diagnose from a bunch of tangled wires which wire is HOT and which is not, and by turning individual circuits on and off I can determine this wire is from circuit 17 and that one is from 32 and that one from 3. My old tester I almost need to touch the wire for it to beep, but the new one beeps the hot wire is 3" away and often a circuit I had off will also beep because the wires may be too close to a hot wire. So basically unless I can pull a wire out of the box and push it away I can't tell which one is hot and which one is not.
Can someone recommend a good reliable non-contact voltage tester?
I found this at Home Depot:
Klein Tools Dual Range Non-Contact Voltage Tester $19.97
I found these two at Lowes (and reviews are not that great):
Greenlee Adjustable Non-Contact Voltage Detector, AC V 5-1000, CAT IV $19.96
Greenlee Non-Contact Volt Detector $13.89
Any thoughts what might work best? Or is there a better choice in that price range?
Thanks in advance.
k_buz 05-21-2012 08:42 PM
I don't use them because I can never truly trust their readings, but I've heard good things about Santronics or the Fluke version.
Ravenworks 05-21-2012 08:47 PM
You need one of these http://www.zorotools.com/g/Circuit%2...ders/00052552/
andrew79 05-21-2012 09:50 PM
the greenlee flluke and klein testers all work really well, The gb and other cheap models pick up power from too far away. Keep in mind that a non contact tester is only the first line of defense and it won't pick up current on a neutral. Great for safety but don't trust them with your life
sevenlol 05-21-2012 09:58 PM
a guy i work with has a Milwaukee brand one, and it has a thumb dial on it to adjust sensitivity, so it will work at the 3 inch range like the one you have, or you can lower it to find a specific wire.
i have the klien brand, and it works fine with finding individual hots, the little bit i've used it.
rrolleston 05-21-2012 11:02 PM
Prefer to use a good multimeter. I have never found a reason to test a mid run somewhere and have heard way too stories where a wrong reading went bad.
Evstarr 05-22-2012 04:33 PM
I prefer to use a non contact tester to narrow things down. But I won't dig in to start tearing things down to work on a circuit till I've checked all conductors with a meter.
