Need To Re-run Bath Fan Switch, Is This Acceptable..??? - Electrical - DIY Chatroom Home Improvement Forum
Old 05-22-2009, 09:44 PM   #1
Need to re-run bath fan switch, is this acceptable..???
I want to install a Levaton timer for my bath fan. Only problem is the current switch is an end run so no neutral. There is currently 14/3 running from the fixture to a dual switch (light and fan). My plan was to rerun a switch leg for the light and use the 3wire for the fan and timer. So at the fixture neutrals and grounds pigtailed to fan and timer, black runs to timer as hot and red is treated as the return hot.
Is there any issue with this? I dont believe so but I was not sure since the hots are essentially on a loop through and the neutral is not.
Wanted to be sure before I do it.
mgarfield is offline   Reply With Quote
Old 05-22-2009, 09:54 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 464
I think I read you right. Running a new switch leg for the light, leaving the 14/3 in place and connecting the white to the neturals in the fan, feed the timer hot with the black, and red as the switch leg.
Works for me!
Old 05-22-2009, 09:58 PM   #3
Thanks JB! Couldn't think of any reasons why I shouldn't do it this way, but I'd rather ask and be told I'm good then not and fry my arse.
4 way switch confusion Richo Electrical 10 04-09-2009 07:11 AM
Adding Bath Exhaust Fan (where to put switch) ande3171 Electrical 14 04-01-2009 07:46 PM
Replacing a bathroom fan switch cmacjr22 Electrical 4 11-04-2008 06:14 PM
old wire, backfed switch question Jack A. Trades Electrical 6 07-03-2008 11:05 AM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 01:19 AM
