Need Power Strip Where Outlets Are "sideways" - Electrical - DIY Chatroom Home Improvement Forum
Old 01-13-2013, 12:04 PM   #1
Rewards Points: 117
Need power strip where outlets are "sideways"
I'm mounting a strip at a closet shelf and need one that has the receptacles oriented against the long axis of the strip.
It only takes one big transformer to crowd over another receptacle and waste a slot.
I need at least a 6-outlet strip. I see monster makes one but it's not as wide as I need. Also, it should be a single row--small space constraints.
Thoughts?
Dornier is offline   Reply With Quote
Old 01-13-2013, 12:21 PM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
My thought is that I don't like outlets in closets to begin with, so an outlet in a closet and a power strip doesn't sound like a good idea to me. JMO
Old 01-13-2013, 12:29 PM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,864
Just shop around. There are TONS of different kind of power strips out there.
Try www.cyberguys.com
I will say, I agree with Kbuz on this one. A power strip in a closet sounds like a bad idea.
Old 01-13-2013, 12:37 PM   #4
Rewards Points: 117
Thoughts on an alternative? I'm not against putting in an AFCI, but I need 5 or so plugs. It's not a walk-in--just a shallow closet under the stairs. There are no garments above or below. It would be about 5' above the floor.
Old 01-13-2013, 01:28 PM   #5
JOATMON
ddawg16's Avatar
Rewards Points: 1,110
Are you by any chance making this a 'data center'? Wireless router, etc?
If so....why not a small UPS? It has outlets on it....and you would have backup power in case of a brown out or power failure.
ddawg16 is online now   Reply With Quote
Old 01-13-2013, 02:21 PM   #6
Rewards Points: 258
http://www.amazon.com/1-Foot-Extensi...octopus+outlet
http://www.amazon.com/Accell-D080B-0...octopus+outlet
redman88 is offline   Reply With Quote
Old 01-13-2013, 02:23 PM   #7
Rewards Points: 117
No it's just a shelf to charge an iPad, leapster pad, some walkie talkies, and a camera.
Old 01-13-2013, 03:38 PM   #8
seansy59's Avatar
Rewards Points: 258
I have 5 of these.....they work great.
http://www.amazon.com/Tripp-Lite-PS2...trip+workbench
seansy59 is offline   Reply With Quote
GFCI outlets lose power, and then get it back kutsyy Electrical 12 02-13-2011 11:38 AM
No power to 2 outlets Partsman41953 Electrical 1 02-07-2011 07:52 AM
Electrical Outlets with Very Low Power goph27 Electrical 6 01-28-2011 09:26 AM
Electrical - Outlets with no power jogan Electrical 5 05-05-2009 03:06 PM
Fuse OK! No power to outlets... henry199 Electrical 9 12-25-2008 09:10 PM
