Old 06-11-2007, 09:40 AM   #1
Need an outlet on my deck.
I'm looking to install an outlet on my deck for my gas grill. What supplies would I need to install it in the floor of the deck?
Jeekinz is offline   Reply With Quote
Old 06-11-2007, 10:20 AM   #2
You'll need to run metal or plastic conduit to make sure it's within code, and it will need to be GFCI. Brackets holding the conduit in place. Anything that is run below ground needs to be via a conduit or water proof, same for the outlet.
handy man88 is offline   Reply With Quote
Old 06-11-2007, 11:13 AM   #3
jproffer's Avatar
Good idea.
Bad idea.
IMHO you're asking for trouble. Water will eventually get into the rec., even if the deck is covered....obviously water in a receptacle is bad
jproffer is offline   Reply With Quote
Old 06-11-2007, 11:32 AM   #4
What can I use for a real clean look? The grill is directly opposite the house.
The deck is about 5' off the ground. Do I need to run conduit under the floor joists? Or just staple the wire?
Old 06-11-2007, 05:52 PM   #5
Master Electrician
JohnJ0906's Avatar
Either conduit or just wire is OK. You will have to use UF cable if just wire. "W" rated conductors if in conduit, or just sleive the UF.
Floor mounting a receptacle outdoors is a BAD idea. I would mount it to the nearest post. Just keep it low. Also, use an "in-use" cover, that you can close when sonething is plugged in.
John from Baltimore
One Day at a Time
"Experience is what you get when you were expecting something else"
"The bitterness of low quality lingers long after the sweetness of low cost is forgotten"
JohnJ0906 is offline   Reply With Quote
Old 06-17-2007, 05:55 PM   #6
Average Joe/ex-Navy IC3
gregzoll's Avatar
Personally, I would use PVC Non-Metallic Schedule 80 Conduit, with at least a 6-12" height above the deck. Make sure that you attach it to either a post, or the outside wall of the house. Also, make sure that you use a GFCI outlet when wiring it.
If it is beyond your scope, you may want to pay the little extra to have an electrician run the wiring, and connect to the breaker panel, and outlet. The running of the conduit, you can pretty much do yourself.
What size deck is 'good' for our situation? curls00 Carpentry 20 09-08-2007 08:12 PM
20a Outlet Vs. 15a Outlet bobo Electrical 3 05-29-2006 11:55 PM
Adding garage outlet Shane Electrical 1 02-23-2006 05:43 PM
European 220V outlet "Schuko" estophile Electrical 6 08-27-2005 09:45 AM
Subfloor question for new deck and solarium CM2U Building & Construction 3 07-27-2005 10:50 PM
